Vibration/Humming Noise 1500-1900 RPM
g1om
Post18-11-2010, 13:03    Subject: Vibration/Humming Noise 1500-1900 RPM Quote
Hello everyone.
I've searched everything again, but unfortunately, I'm still not any wiser.
My ARL engine, with 177,000 km on the odometer, starts with a strong knocking/vibration in gears 5/6 at an RPM range of 1500-1900.
In the lower gears, the engine speed range is traversed more quickly, which is why this phenomenon is less pronounced.
In this case, the interior rearview mirror vibrates so strongly that it becomes impossible to see anything.
Having encountered information about ZMS/engine mounts here, I would like to know to what extent this error pattern might apply to my situation. Also, what is your assessment of the likelihood that these components are defective?
Other issues such as clutch slippage or annoying noises do not occur.
'Errors are both cold and present. Error codes are not stored.'
Thank you in advance.
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards' in English.
Translated on 26-09-2026, 3:29.
Post18-11-2010, 13:51    Subject: Vibration/Humming Noise 1500-1900 RPM Quote
ZMS, engine mount, or tuning with excessive torque.
Translated on 26-09-2026, 3:30.
g1om
Post19-11-2010, 16:55    Subject: Vibration/Humming Noise 1500-1900 RPM Quote
You're welcome for the information. I'll be replacing the timing belt during the major inspection, and I'll also replace the engine mounts at the same time.
I will choose ZMS if things don't improve.
The engine is largely in its original condition (no modifications).
I will keep you updated.
Translated on 26-09-2026, 3:31.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post19-11-2010, 19:07    Subject: Vibration/Humming Noise 1500-1900 RPM Quote
there's a strong booming/vibration
in the hallways 5/6.
It feels like the problem lies in the rubber bushings, such as those in the control arms, strut mounts, engine carrier, engine mounts, and the lower engine support.
At lower temperatures, they become slightly harder, which results in a different sound profile compared to when they are very hot.
reflexsilber met.
Translated on 26-09-2026, 3:32.
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts Golf 1J: Grinding Noises in All Gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Full-load trucks AFN 1500-1900/min, only with hot PÖL Diesel Engine Technology
No new posts Engine Vibration at Idle: Causes & Fixes Diesel Engine Technology
No new posts Tiptronic A6: Gap Between Gears - Problem? On-Board Diagnostics (OBD)
No new posts Is a roaring sound from the 1Z engine at approximately 15... Diesel Engine Technology
