AHU: Idle Speed Issues
blackblizzard
Post19-11-2010, 13:56    Subject: AHU: Idle Speed Issues Quote
Hello!
My AHU vibrates quite strongly when idling, to the point that the exhaust rattles.
I read that you can adjust the fuel mixture slightly. Would it also help to increase the idle speed?
PS: Otherwise, the engine is running perfectly!
Translated on 01-11-2026, 17:46.
Diesel_Rudi
Post21-11-2010, 0:15    Subject: AHU: Idle Speed Issues Quote
If the injectors and the compression are okay, it's usually the pump. Otherwise, it's likely a problem with the glow plugs. Check the mileage and error codes in the diagnostic system. I doubt there's a specific error code for this.
Translated on 01-11-2026, 17:47.
blackblizzard
Post21-11-2010, 17:55    Subject: AHU: Idle Speed Issues Quote
Memory is empty, 240,000 km mileage.
Exactly, when I slightly increase the speed (with the accelerator), it runs smoothly.
Karma: +1359 / -0   Thank you, like it!
Post21-11-2010, 20:00    Subject: AHU: Idle Speed Issues Quote
First, regarding your two questions
, I read that the amount of feed can be adjusted somewhat
. No, that's not how it works. A higher feed rate means a higher speed.
Would it also be beneficial to increase the idle speed?
It might be possible within certain limits, but that probably won't eliminate the problem of the engine running unevenly at the target low-speed RPM. With the throttle test, you probably increased the RPM by about 100 min-1.
If it's not worn engine mounts, then this is actually a case for a proper diagnosis. However, since we have rules for providing support, please enter your VCDS license.
"vg" is an abbreviation for "very good". It is often used in online forums and chat rooms to express agreement or approval.
Translated on 01-11-2026, 17:49.
Karma: +807 / -0   Thank you, like it!
Post21-11-2010, 20:20    Subject: AHU: Idle Speed Issues Quote
Please check measurement block 13 in the engine control unit and use the search function. Thank you.
No VCDS-RKS license.
http://lmgtfy.com/?q=vcds+rks
Translated on 01-11-2026, 17:50.
No new posts AHF MKB: Troubleshooting Idle Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BDG - unstable idle during warm-up phase Diesel Engine Technology
No new posts Polo 6R: Handling issues at high speed on highways Transmission, Chassis, Body & Interior
No new posts CXXB Injectors: Loud Backfire & Rough Running Diesel Engine Technology
No new posts Engine Misfire & Vibration: Causes & Fixes Diesel Engine Technology
