reuselkopp Blaumann
15-06-2011, 19:26 Subject: Small Battery Box for ASZ - Save Space! |
Hello everyone,
I'm having a problem with my battery tray and cover. Since I replaced the standard air intake system in my Golf 4 Variant with the one from the R32 DSG, the battery tray only fits very tightly, and the cover doesn't fit at all. Because the battery I have installed, which is 70AH/340A, still has quite a bit of space on the sides, I would like to install a smaller battery tray and cover.
Installed is: 1J0 915 333 battery holder, 70AH/340A, 80AH/380A.
1J0 915 335 B Battery cover.
Would a battery terminal with the code 1J0 915 333 A, designed for a 44AH/220A battery and compatible with a 60AH/280A battery, fit my battery, along with the corresponding cover?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 29-10-2026, 16:53.
15-06-2011, 21:36 Subject: Small Battery Box for ASZ - Save Space! |
Did you install everything correctly? I have the same unit and also converted it to the larger intake, but everything fits perfectly for me, just like before.
Translated on 29-10-2026, 16:54.
Profile PM Garage |
reuselkopp Blaumann
16-06-2011, 6:47 Subject: Small Battery Box for ASZ - Save Space! |
Hello.
"I think I've put everything back together correctly this time. It's not particularly difficult. The expansion rivets fit, which means the position of the pipe attachment is correct, and the pipe itself is fastened to the inside of the fender. That also seems right. Perhaps the screw for the pipe is a bit further out on your G4 model. My G4 is model 05, one of the later ones, so maybe something was changed. I was even considering moving the attachment point where the pipe is screwed to the fender, but I'm not sure if the adhesive would hold."
Greetings.
Reuselkopp.
Translated on 29-10-2026, 16:55.
reuselkopp Blaumann
17-06-2011, 7:16 Subject: Small Battery Box for ASZ - Save Space! |
Hello everyone,
"Does anyone have access to the AKTE database to check the dimensions of the console with part number 1J0 915 333 A, which is the 44AH/220A battery console, 60AH/280A, and its corresponding cover?"
Thank you and best regards.
Reuselkopp.
Translated on 29-10-2026, 16:56.
reuselkopp Blaumann
19-06-2011, 13:35 Subject: Small Battery Box for ASZ - Save Space! |
Hello, I'm feeling desperate.
Does anyone have some dimensions for me? Is this information available in the VW program documentation (AKTE)?
Greetings.
Reuselkopp.
Translated on 29-10-2026, 16:57.
30-06-2011, 14:22 Subject: Small Battery Box for ASZ - Save Space! |
The dimensions are usually NOT included.
Sorry.
Profile PM Garage |
Octavia_4x4 Schrauber
06-07-2011, 13:26 Subject: Small Battery Box for ASZ - Save Space! |
Big intake?  GTI, give me some info, could this work for me too?  Mine is so slow.
Translated on 29-10-2026, 16:58.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
22-07-2011, 23:39 Subject: Small Battery Box for ASZ - Save Space! |
The pre-facelift Audi A3 has a battery holder that is quite narrow, allowing the battery to be easily shifted to the left or right.
Maybe this will help?
Profile PM Garage |
