Power Steering Pump Audi V6 TDI - Replacement?
luiggi
Post11-12-2010, 11:16    Subject: Power Steering Pump Audi V6 TDI - Replacement? Quote
After my steering gear started leaking, which also damaged my pump (the steering becomes extremely difficult at times, and when the engine speed increases, the steering power becomes lighter again), I would appreciate some brief assistance.
Can someone help me with the best way to replace the power steering pump on my V6 AKE engine? Does the front of the car absolutely need to be in service position, or is there another way to do it? A brief description would be very helpful. Thanks.
Translated on 25-10-2026, 21:17.
Post11-12-2010, 11:53    Subject: Audi V6 TDI Power Steering Pump Replacement? Quote
luiggi wrote:
So, it's absolutely necessary to put the front
in service mode, or is there perhaps another way to do it? }Without service mode, you won't be able to remove the ribbed belt; there's no chance.
Translated on 25-10-2026, 21:19.
luiggi
Post11-12-2010, 12:07    Subject: Power Steering Pump Audi V6 TDI - Replacement? Quote
I wouldn't have been surprised, but supposedly someone already did it somewhere on the internet, without using a special tool. I personally don't believe it's possible. The space constraints with the V6 TDI engine are extreme.
I'll get around to replacing the pump on Tuesday, and I'll put the front in service mode as described. It would be really interesting to see who could manage to do something like that without any issues. Best regards.
Post11-12-2010, 17:18    Subject: Power Steering Pump Audi V6 TDI - Replacement? Quote
luiggi wrote:
...but somewhere on the internet, someone supposedly did that already, without using the service position?
I bet that person didn't finish any faster than if they had put the front end in the service position.
Translated on 25-10-2026, 21:20.
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the engine control unit (ECU) for an Audi A4 B5... Gasoline Engine Technology
No new posts Replacing xenon ballast, Audi A3, but how? Transmission, Chassis, Body & Interior
No new posts Audi A4 power steering pump axial play Gasoline Engine Technology
No new posts Replace intake manifold pressure sensor in the control unit? Diesel Engine Technology
