Reverse gear problem Audi A4 8D 1.8T Multitronic, first registration 03
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
schlauchdruide
Post17-01-2011, 15:25    Subject: Reverse gear problem Audi A4 8D 1.8T Multitronic, first registration 03 Quote
Unfortunately, I couldn't find a suitable answer in the forum.
The Audi sometimes fails to shift into reverse. However, the following procedure often works: Put the car in neutral, turn off the engine, restart it, and then it usually shifts into reverse.
'The following error occurred:'
17090 Step sensor (F125) - implausible signal.
P0706-35-00--
Are there any known issues? Is it possible or necessary to replace the sensor?
bloesch
Post17-01-2011, 19:43    Subject: Reverse gear problem Audi A4 8D 1.8T Multitronic, first registration 03 Quote
hello,
You'll probably need a new transmission control module; the sensor is located inside it, as far as I know.
btw: your A4 is an 8E (the 8D is the previous model).
schlauchdruide
Post17-01-2011, 20:13    Subject: Reverse gear problem Audi A4 8D 1.8T Multitronic, first registration 03 Quote
That doesn't sound good at all.
Is it possible to confirm the suspicion using VAG-Com (I have entered the serial number in my profile)?
I'm not very good with electronics; I'm a mechanic specializing in engines.
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reverse Gear Not Working: Doku Sharan Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem: Electronic Parking Brake (S-Tronic) in Audi A4, ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 B8 2,7 TDI Multitronic Probleme Transmission, Chassis, Body & Interior
No new posts Audi A6 C5 Allroad transmission conversion: from Multitro... Gasoline Engine Technology
No new posts Grinding noise in reverse Diesel Engine Technology
No new posts Passat Tiptronic Rückwärtsgang defekt Diesel Engine Technology
