Passat 3B: Oil in Coolant - Causes & Fixes
chli1976
Post13-02-2011, 15:06    Subject: Passat 3B: Oil in Coolant - Causes & Fixes Quote
I have a Passat that is pushing oil into the coolant.
After that, I replaced the oil cooler, and it was quiet for 250-300 kilometers.
Now, it's leaking oil into the coolant again.
Oil cooler again, or something else?
The original radiator had the part number 028 117 021L.
I installed one with the number 028 117 021B. It was from an automotive parts store.
According to the dealer, index B was changed to K and L. Were there any issues with that?
Edit: An AVB is not an AJM.
VCDS
Translated on 02-09-2026, 0:35.
chli1976
Post13-02-2011, 15:38    Subject: Passat 3B: Oil in Coolant - Causes & Fixes Quote
I'm going to bypass the water connections on the oil cooler and see what happens.
VCDS
Translated on 02-09-2026, 0:36.
No new posts Handwashing on the go, without water General Tips
No new posts Doku Polo 9N, water accumulates in the footwell during he... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wasser im Fußraum nach Regenschauer, Passat Var 7/99 Transmission, Chassis, Body & Interior
No new posts Water Damage ASZ: Causes & Prevention Diesel Engine Technology
No new posts Water in the lock... Transmission, Chassis, Body & Interior
No new posts Water = 100°C at the source, but only 13°C outside!! Diesel Engine Technology
