Audi S3 Alloy Wheels on VW Golf IV Variant?
Marco
Post22-03-2003, 13:47    Subject: Audi S3 Alloy Wheels on VW Golf IV Variant? Quote
Hello fellow enthusiasts,
'Will the standard 17' 6-spoke alloy wheels from an Audi S3 fit a G4 Variant with standard suspension without any modifications? The wheels have the following dimensions: 7.5J x 17 ET32, 5x100 bolt pattern. And will they be technically approved by TÜV (German technical inspection agency)?'
Translated on 07-10-2026, 6:29.
Post24-03-2003, 16:22    Subject: Audi S3 Alloy Wheels on VW Golf IV Variant? Quote
I once heard that with the G4, you can only fit/are only allowed to have 17-inch wheels if they were originally installed from the factory and registered.
These vehicles would have a different steering system.
Source: www.volkstreff.de
Greetings.
martin
Translated on 07-10-2026, 6:30.
Post24-03-2003, 16:55    Subject: Audi S3 Alloy Wheels on VW Golf IV Variant? Quote
No.
"This rim is not approved for use on any Golf model. As a 17-inch wheel, the factory-installed options are only 7x17 ET 38 (Sport Edition), and more recently, the Evolo STP in the same size (GT Sport). Even with the 7x17 Santa Monica wheels, there can sometimes be issues with registration if the car does not have the standard sport suspension."
You need to register the Audi rims. Since there is no certificate of conformity or approval document (ABE), you will have to rely on Audi's goodwill and the judgment of the person at the TÜV (technical inspection authority). You should simply ask the TÜV person what requirements need to be met.
In terms of its dimensions, there shouldn't be many problems. However, the tire size is likely something that the TÜV inspector would be interested in.
Translated on 07-10-2026, 6:31.
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rotating Rear Wiper Nozzle for VW Golf 4, Audi A3 8L Troubleshooting & Guides
No new posts Torque Specs: Alloy Wheel Lug Nut Tightening Transmission, Chassis, Body & Interior
No new posts Remove Stuck Alloy Wheels: Easy Guide & Tips Transmission, Chassis, Body & Interior
No new posts Golf 6 Variant: Heated Steering Wheel Transmission, Chassis, Body & Interior
No new posts Golf 3 Variant Net Separator Grill Transmission, Chassis, Body & Interior
