Seat Occupancy Detection VW Touran 2005
Post15-04-2011, 18:16    Subject: Seat Occupancy Detection VW Touran 2005 Quote
I'm getting a 2005 Touran next weekend that has a faulty seat occupancy sensor and keeps beeping even when the seatbelt is fastened. The workshop couldn't fix it, and my friend wants to drive this car to France this Sunday.
Can I simply disable the seatbelt warning like on the G VI using a long coding sequence?
And even more importantly: does the fault detection system affect whether or not the relevant airbag is deployed?
Translated on 27-07-2026, 23:05.
Post15-04-2011, 19:06    Subject: Seat Occupancy Detection VW Touran 2005 Quote
Roger wrote:
Can I simply deactivate the seatbelt warning like on a G VI using long coding?
Yes, it shouldn't even require long coding yet. In other words, it should be configured in the same way as you might remember from your old Golf 4.
Roger wrote:
And even more importantly: does the fault detection influence whether the relevant airbag is deployed?
Translated on 27-07-2026, 23:06.
Post15-04-2011, 19:10    Subject: Seat Occupancy Detection VW Touran 2005 Quote
Thank you!
Translated on 27-07-2026, 23:07.
Ross-Tech-Support
Post18-04-2011, 19:52    Subject: Seat Occupancy Detection VW Touran 2005 Quote
If you disable the warning about the encoding, nothing changes in the evaluation of the airbag system. In case of a defect, as in this case, it naturally becomes questionable, although the official position of VW/Audi is probably that this only matters in the North American market - but I wouldn't rely on that. icon_wink.gif
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Engine Failure 1.9 TDI 105 PS Touran Diesel Engine Technology
No new posts VW Touran: Driving Without AC - 2005 Model Diesel Engine Technology
No new posts Audi A4 B7: Seat Occupancy Disable Coding On-Board Diagnostics (OBD)
No new posts Altea 2.0 FSI: Specs & Info for 2005 Model Gasoline Engine Technology
