A4 B6 (AVB) Troubleshooting Guide
clemo2006
Registered VCDS User
Post22-04-2011, 19:59    Subject: A4 B6 (AVB) Troubleshooting Guide Quote
Hello!
I'm new here and looking for a solution to a problem with my Audi A4 B6 (AVB).
Unfortunately, no icon_smile.gif can help any further; several visits to different specialized workshops have been unsuccessful.
In my opinion, the B6 engine feels like it's lacking power, mainly in the lower RPM range, and sometimes only manages to reach 100 km/h. There are some unusual engine control unit (ECU) behavior patterns, see attachments. The EGR valve is new, as is the solenoid valve. The intake manifold pressure sensor is also new. The turbocharger has been disassembled, cleaned, and the variable turbine geometry (VTG) linkage is working smoothly. The error memory is also empty even after many test drives.
Who can help me?
Regards cleMo
 File size:  55.87 KB
 Viewed:  2525 times
LOG-012-003-008-011.CSV
 File name:  LOG-012-003-008-011.CSV
 File size:  1.6 KB
 Downloaded:  641 times
Translated on 02-11-2026, 21:21.
haithamina
Post22-04-2011, 22:12    Subject: A4 B6 (AVB) Troubleshooting Guide Quote
The engine speed is quite high, and the target air mass is not being achieved.
At full throttle, the overboost is significant, and it's being limited by the smoke reduction system despite almost reaching the maximum boost pressure, likely due to a "lack of air." I would try replacing the mass airflow sensor (MAF).
haithamina
Translated on 02-11-2026, 21:23.
clemo2006
Post23-04-2011, 5:05    Subject: A4 B6 (AVB) Troubleshooting Guide Quote
Hello haithamina!
Thank you for the quick message! The Passat was/is also available with the AVB, that's correct! icon_idea.gif
One of the many icon_smile.gif connected a new mass airflow sensor last year, tested it, compared it, and then reinstalled the "old" one, saying, "Unfortunately, it's not working either!"
Are there any reference values for this, or wouldn't there be something recorded in the error memory?
Regards cleMo
Translated on 02-11-2026, 21:24.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post23-04-2011, 5:16    Subject: A4 B6 (AVB) Troubleshooting Guide Quote
Please enter your VCDS license number in your user profile!
Thank you.
Passat Variant BGW 2005
Translated on 02-11-2026, 21:25.
clemo2006
Post23-04-2011, 5:36    Subject: A4 B6 (AVB) Troubleshooting Guide Quote
Thank you.
Just finished, thank you!
Regards cleMo
No new posts Troubleshooting manual air conditioning system, Volkswage... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Troubleshooting Performance Issues Troubleshooting & Guides
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKE Troubleshooting: Common Errors and Solutions On-Board Diagnostics (OBD)
No new posts TDI VTG/N75 Troubleshooting: Common Issues & Fixes Diesel Engine Technology
No new posts Troubleshooting Climatronic Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Guided troubleshooting with VAG Com? On-Board Diagnostics (OBD)
