Hard to believe, but true!
My friend bought a T4 van a year ago.
In order to get it registered in Austria, several repairs were carried out at a workshop in Vienna.
She also had the timing belt replaced.
Since the vehicle had a significant backlog of repairs, I have been busy addressing those issues.
Now, the cosmetic issues came up, like a vibration noise coming from the engine compartment. Yes, I know, you're saying "dummy"
I suspected the serpentine belt tensioner, but it turned out to be in good condition.
After that, remove the timing belt cover and
Holla the forest fairy!!!
The timing belt was completely loose!!!
There was, without exaggeration, less than 0 volts of voltage.
So, I went to my friend who's a mechanic, and he immediately noticed the timing belt tensioner.
He said the screw was broken and that it was clearly the fault of the workshop where she had the timing belt replaced.
You often hear horror stories about the T4 timing belt.
But the fact that the engine even ran for 1 kilometer is a miracle.
That noise has been there from the beginning.
And we drove cheerfully across Swiss mountain passes and through half of Germany.
After the repair, I realized how quiet a 2.5 TDI engine can actually be.
He had experienced strong vibrations while the car was stationary, and it also felt unpleasant when shifting gears.
I attributed the vibrations during gear changes to the dual-mass flywheel.
I actually wanted to sue the shoddy repair shop, but my girlfriend was just relieved that we escaped without any engine damage.
And the moral of the story? Don't trust any amateur
except yourself.
