karlstein12 Blaumann
04-07-2011, 21:14 Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. |
"In my Passat 3B, manufactured in March 2000 and equipped with a 5-speed transmission, the resistance that separates the shifting levels between gears 3/4 and gear 5 is no longer present."
"That is, when shifting into 3rd gear..." Sometimes you hear the third harmonic, but sometimes the fifth, and occasionally something in between, which produces an unpleasant sound.
I've removed the gear lever cover before, but I didn't get any further than that.
Before I take everything apart, can someone tell me where this resistance is coming from - at the shift linkage or at the transmission?
Does anyone know this problem, or its solution?
MKB: ATJ
GKB: EYZ
Sure, no problem. Here's the translation:
"Thank you in advance."
Greetings.
Rupert.
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
04-07-2011, 21:43 Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. |
Do the drawers slide in and out easily without scratching? Check the shift actuator; the shift rod that goes into the transmission may be defective - requires a workshop visit.
reflexsilber met.
Profile PM Garage |
voodoo Guest
04-07-2011, 21:47 Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. |
The 3B Bj3/2000 still uses the old linkage system.
It might be worth considering stopping it.
However, the shift linkage is generally always a bit more clunky than the later cable-operated systems.
05-07-2011, 12:45 Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. |
The mechanism isn't actually complicated, and the gears fit in perfectly. I've also already checked the gear shift linkage; it's easily accessible from above.
Normally, the gear lever is in neutral in the 3/4 position. To shift into first or second gear, you push the lever to the left. To shift into fifth gear, you need to overcome the resistance by pushing the lever to the right. For some time now, the gear stick in my car has been getting stuck in a position somewhere between left and right, with no resistance.
It would be helpful to know how the gear lever is held in the 3/4 position when in neutral (e.g., by a spring). Possibly, I can then narrow down the source of the error and, consequently, the amount of work required for disassembly.
Rupert.
RedR32 Schrauber
05-07-2011, 17:58 Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. |
karlstein12 wrote: |
How the gear lever is held in the 3/4 position when in neutral (e.g., by a spring).
Rupert |
Hi, there are locking screws installed in the transmission. These are screws with a small, spring-loaded ball that locks into the recesses on the shafts. This is all part of the shifting mechanism. These locking screws are usually replaceable from the outside.
I would check these locking screws first.
reflexsilber met.
Profile PM Garage |
06-07-2011, 20:59 Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. |
Hello RedR32,
That was the right tip!
I found two locking screws on the camshaft. Out of those, one actually had no tension left on the spring/ball.
I'll order those tomorrow, then it should fit again.
Thank you and best regards.
Rupert.
