Ford Focus: Metallic Squealing Noise, 90HP TD
Faxe
Post23-10-2012, 19:45    Subject: Ford Focus: Metallic Squealing Noise, 90HP TD Quote
Hello fellow forum members,
Today, I'm reaching out to you about a diesel engine that's not the usual type.
Ford Focus, manufactured in 2002, 66 kW / 90 hp, TD (Turbo Diesel).
Problem: Metallic squealing noise starting at 1400 RPM.
Ear localization, centered on the engine block.
Localization using a body sound probe: The tensioning roller for the V-ribbed belt is making noise.
-> Replaced the roller today, but the squeaking persists. The noise from the roller itself is gone.
The squealing noises cannot be located, even with a body sound probe icon_sad.gif.
What other methods are there for locating the source of the noise?
Or is anyone else familiar with this issue in the Focus Diesel?
Looking forward to more ideas!
Faxes.
Translated on 08-10-2026, 4:45.
Post23-10-2012, 19:59    Subject: Ford Focus: Metallic Squealing Noise, 90HP TD Quote
Is the timing belt, along with its pulleys and water pump, hidden behind a ZR cover? Perhaps it's worth looking there!
Translated on 08-10-2026, 4:47.
Karma: +590 / -0   Thank you, like it!
Post26-10-2012, 22:10    Subject: Ford Focus: Metallic Squealing Noise, 90HP TD Quote
Hi!
Or try running the engine briefly without the belt that drives the auxiliary components.
When it's gone...
Faxe
Post28-10-2012, 23:48    Subject: Ford Focus: Metallic Squealing Noise, 90HP TD Quote
Good evening.
Thank you for the tips icon_biggrin.gif.
Here's the result:
Short test run without the serpentine belt, the noise remains. The source is clearly not the timing belt.
To test the exhaust system, I sealed the exhaust pipe, and the noise is still present when the engine is idling.
The engine won't stall, therefore the exhaust system has a leak.
Exhaust fumes are coming from the engine compartment, also visible on the exhaust manifold. It's likely a faulty gasket, and as the exhaust pressure increases, it makes a whistling sound, although it sounds very much like a metallic squeak.
Has anyone ever removed the exhaust manifold from a 1.8 TDI engine?
Faxes.
Translated on 08-10-2026, 4:48.
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford Focus 1.8 TD timing belt replacement Diesel Engine Technology
No new posts 1.6 PSA Diesel in the 2005 Ford Focus Diesel Engine Technology
No new posts Focus TDDI 90hp problem / P0235 boost pressure sensor &am... On-Board Diagnostics (OBD)
No new posts Can I retrofit a Ford Focus Ghia TDCi with a new onboard ... Transmission, Chassis, Body & Interior
