Sleep Mode control units when the key is in the ignition?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post06-09-2011, 21:27    Subject: Sleep Mode control units when the key is in the ignition? Quote
I'm curious to know if the engine control units enter sleep mode when I turn off the engine and then don't remove the key from the ignition.
Vehicle: VW Caddy, year 2008, 1.9 TDI.
Background: The vehicle is brought to the workshop in the evening, and my colleagues don't remove the key; they simply leave it in the ignition.
The ignition switch "switches" again when I remove the key, for example, turning off the radio and turning on the interior light.
Best regards, Thilo.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post06-09-2011, 21:57    Subject: Sleep Mode control units when the key is in the ignition? Quote
Hi, I'm not entirely sure, but I think they only sleep properly when the car is completely locked.
reflexsilber met.
michiglaser
2007 Audi A4 Avant
Post08-09-2011, 17:59    Subject: Sleep Mode control units when the key is in the ignition? Quote
The situation is likely to occur more often, and I doubt that it wasn't considered during the development process.
Clarity likely only comes from exhibitions.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Post08-09-2011, 18:45    Subject: Sleep Mode control units when the key is in the ignition? Quote
If the Caddy has survived one night already, they're probably going to sleep.
My Passat was completely drained of power after a night during which I had the VCDS cable connected but the car locked.
klahaui
Avatar-klahaui
Post08-09-2011, 19:04    Subject: Sleep Mode control units when the key is in the ignition? Quote
He's even managed to survive that for 3 years icon_smile.gif.
Yes, I followed your thread, but I wasn't completely sure about it.
The second point is that my father also experiences the same issue with his Ford at work, and I've been having a starting problem with it. Replacing the 6-month-old battery helped, but the problem hasn't completely disappeared.
Post08-09-2011, 22:19    Subject: Sleep Mode control units when the key is in the ignition? Quote
dieselmartin wrote:
If the Caddy has survived one night before, they will probably go to sleep.
That's right. If you don't sleep in a car like that, you usually reach your limit after about 10 hours.
"That kind of car can easily draw 4-5 amps."
klahaui
Avatar-klahaui
Post08-09-2011, 22:49    Subject: Sleep Mode control units when the key is in the ignition? Quote
I wouldn't have expected this much.
But thank you so far, I'm quite a bit smarter now icon_cool.gif.
No new posts EDC15 Steuergeräte, Software updatefähig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 - Strom für Radio ist weg wenn Zündung aus Transmission, Chassis, Body & Interior
No new posts Audi Concert II: Troubleshooting & Safe Mode Fix Diesel Engine Technology
No new posts Polo 9n fog lights turn on with ignition Electrical Systems, Vehicle Electronics, Multimedia
No new posts Supply voltage for steering angle sensor G85: Ignition an... On-Board Diagnostics (OBD)
