New Bosch VP37 Injector Replacements
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
dieselschrauber and Herbert likes this.
Post06-11-2024, 13:09    Subject: New Bosch VP37 Injector Replacements Quote
Hello fellow diesel mechanics!
I want to treat my VW T4 2.5 TDI to new, original Bosch injectors for its 600,000 km milestone. They were last overhauled at 300,000 km, and now they're starting to smoke slightly when idling.
It's important to me that I don't install any fireworks made in China. However, even after hours of searching, I can only find imitation nozzles.
Could it be that Bosch no longer manufactures these injectors?
The Bosch customer service would not provide me with any information on this matter, as these types of products are only sold from business to business.
It's specifically about the DSLA150P764 nozzles with a size of 0.216mm.
Alternativ Bosio Sprint 502, 0.217mm.
Bosio Power Plus 502, 0.232mm. Dieselkontor and H-Turbo, which might have listed these nozzles, don't actually have them. It's much more amusing when potential buyers send inquiries for nothing.
Or did you actually come up with alternatives that were of comparable quality?
Thank you for your ideas!
Translated on 08-07-2026, 22:31.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
Post06-11-2024, 18:25    Subject: New Bosch VP37 Injector Replacements Quote
Hello Tagessuppe,
Bosch has changed the product code.
The new number is: 2 437 010 060
Damit bist du wieder im Rennen und findest auch org. Bosch parts.
Michael.
Translated on 08-07-2026, 22:32.
Tagessuppe
Post06-11-2024, 18:28    Subject: New Bosch VP37 Injector Replacements Quote
Hello!
This number has also appeared for me before, but it is listed as AKN/AFB Düse.
Translated on 08-07-2026, 22:33.
Post06-11-2024, 21:26    Subject: New Bosch VP37 Injector Replacements Quote
Tagessuppe wrote:
Hello!
Diese Nummer wurde mir auch schon angezeigt, jedoch wird diese Nummer als AKN/AFB Düse gelistet.
So, if I enter the number into Google, it finds DSLA 150P764, which is correct. icon_wink.gif
Tagessuppe
Post06-11-2024, 23:09    Subject: New Bosch VP37 Injector Replacements Quote
That is, of course, also correct when you consider the reverse.
However, when I want to buy nozzles like that,
"This message appears on a Passat 2.5 V6 TDI."
And I wouldn't buy them based on a hunch, as they are excluded from returns.
 File size:  336.88 KB
 Viewed:  795 times
Translated on 08-07-2026, 22:34.
Post06-11-2024, 23:33    Subject: New Bosch VP37 Injector Replacements Quote
I sent you a link (for example, via private message), and I don't want to post any promotional links here.
Tagessuppe
Post07-11-2024, 11:22    Subject: New Bosch VP37 Injector Replacements Quote
Thank you for the link!
However, the same applies: Suitable for VW Passat 2.5 AFB/AKN engines.
Translated on 08-07-2026, 22:35.
Herbert likes this.
Post07-11-2024, 12:45    Subject: New Bosch VP37 Injector Replacements Quote
"Just make sure to verify the phone number when placing the order."
Tagessuppe
Post27-01-2025, 17:02    Subject: New Bosch VP37 Injector Replacements Quote
Hello, fellow diesel mechanics!
After Bosch responded that the nozzles should be available again starting in November, which of course they were not, I was able to find them in England.
DSLA150P764 0433175176 was the exact designation.
Als ich die Köpfe verbaut habe, stellte ich an den Düsen welche ich vor 10 Jahren bei 300.000km ausgebaut hatte fest, dass die Federn durch die Lagerung leichten Flugrost angesetzt haben. Ich bin mir nicht sicher wie sich der Kraftstoff genau in der Düse verteilt, habe aber wenig lust mir meine neuen Düsen zu zerstören. Man könnte eventuell mit etwas nicht abrasiven strahlen, zB Mehl, jedoch habe ich da trotzdem ein komisches Gefühl. Weiss jemand zufällig wie es sich mit Fremdkörpern in Einspritzdüsen verhält? Ich meiI once read that there's a sintered metal filter inside.
Okay, and for my A2 3L 1.2 TDI, I'm looking for a DSLA 156 P 1041.
You can probably also forget about finding something like that. icon_sad.gif
Translated on 08-07-2026, 22:36.
dieselschrauber likes this.
Post27-01-2025, 19:48    Subject: New Bosch VP37 Injector Replacements Quote
"Hello. Are you restoring a classic car?"
Actually, the feathers are in the bucket. If the feathers also had a surface treatment, they are even more in the bucket.
A little bit of restoration might be possible.
Remove the surface rust with a nylon brush or a brass brush, then place the springs in a 10% citric acid solution. Check frequently; the steel should only become clean, not eaten away.
Do you know any electroplaters? They might be able to use nitric acid for this, and they have a sense of how long the etching process should take.
Deep notches indicate where the fracture will likely occur later.
And remember, the feathers are part of the nozzle assembly.
Translated on 08-07-2026, 22:37.
Post27-01-2025, 21:30    Subject: New Bosch VP37 Injector Replacements Quote
Important note: All components of a DHK (Deutsches Hochkreuz - German Cross) are individual pieces! Do not (!!!) dump everything together.
Otherwise, only Rainer can sort it out, but he doesn't have the time or the inclination to do so. X
Translated on 08-07-2026, 22:38.
Tagessuppe
Post27-01-2025, 22:14    Subject: New Bosch VP37 Injector Replacements Quote
Herbert wrote:
Hello. Are you restoring a "classic car"?
"It's not a direct restoration, but my 1997 T4 is already producing too much smoke, even at idle. At 600,000 km, the injectors might need to be replaced."
Of course, I know that everything should fit in exactly the same way as before, as long as you don't have a testing device to check the opening pressure of the second stage.
I will simply overhaul the currently installed nozzle holders, carefully remove the rust from the rusty ones, fill them with test oil, and seal them to prevent this from happening again.
Translated on 08-07-2026, 22:39.
Tagessuppe
Post04-02-2025, 10:47    Subject: New Bosch VP37 Injector Replacements Quote
I have now overhauled the built-in nozzle holders, which I last overhauled almost exactly 300,000 kilometers ago. I set the opening pressure to 220 bar back then. Now it's between 170 and 190 bar.
Since I was using inexpensive nozzles back then, I was expecting that only a few of the holes would have flow, and that the nozzles would produce a more stream-like spray rather than a mist.
But I certainly didn't expect that!
Dass die Teile so schön schnarren nach dieser Laufleistung, damit hätte ich nicht gerechnet. AThey were all like that.
May I actually mention which German company it was?
New Bosch VP37 Injector Replacements - WhatsApp Video 2025-02-02 at 11.46.15.mp4
 File size:  1.72 MB
 Viewed:  214 times
Translated on 08-07-2026, 22:41.
Tagessuppe
Post04-02-2025, 11:31    Subject: New Bosch VP37 Injector Replacements Quote
And here's another video showing original Bosch injectors after 300,000 km.
New Bosch VP37 Injector Replacements - WhatsApp Video 2025-01-05 at 15.07.33.mp4
 File size:  2.62 MB
 Viewed:  208 times
Translated on 08-07-2026, 22:42.
Post04-02-2025, 16:31    Subject: New Bosch VP37 Injector Replacements Quote
Darf ich eigentlich schreiben welche Deutsche Firma das war?
Okay, please provide the text you would like me to translate from German to English.
Tagessuppe
Post04-02-2025, 16:34    Subject: New Bosch VP37 Injector Replacements Quote
Thank you very much!
The nozzles were manufactured by Dieseltechnik Biberach.
No new posts Bosch ABS/ESP 5.3: Basic Settings & Configuration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Error codes and possible causes for Bosch ABS Version 5.0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4 nozzles with NHG instead of 3 standard nozzles Diesel Engine Technology
No new posts New Ibiza: 96 kW Power & Performance Diesel Engine Technology
No new posts New Wireless Key: Features & Benefits On-Board Diagnostics (OBD)
No new posts A new and more powerful TDI is needed Diesel Engine Technology
