Held467 Blaumann
02-12-2011, 20:14 Subject: V6 TDI Head Gasket Failure |
Hi.
This is probably a silly question, but how can I tell which side of a V6 TDI engine is faulty?
Immediately after starting, the engine builds up pressure, or, if the expansion tank is open, it bubbles out of the rear connection that comes from the center of the engine block. It's hard to explain, but I can take some pictures tomorrow.
The engine is a BAU.
Dirk
Translated on 04-10-2026, 19:34.
Herbert Profi-Schrauber
02-12-2011, 21:51 Subject: V6 TDI Head Gasket Failure |
Hello there,
I would like to try it out.
- the idle speed control.
- the compression.
There might be a cylinder exposed, which could also reveal the head.
Herbert. Horch A4 8K CJCD
Translated on 04-10-2026, 19:35.
gullianderle Guest
03-12-2011, 10:55 Subject: V6 TDI Head Gasket Failure |
I would definitely remove both cylinder heads. Otherwise, there's a risk that the second cylinder head or its gasket might fail after a certain amount of time. And then having to disassemble everything again, essentially starting from scratch, is very time-consuming.
Translated on 04-10-2026, 19:36.
Held467 Blaumann
03-12-2011, 11:37 Subject: V6 TDI Head Gasket Failure |
Hi.
Okay, I've removed both of them, and it was the one on the right side, so numbers 1, 2, and 3.
She easily won from 1 to 2 and went straight into the water.
I'm going to make everything look really flashy and put it all back together.
Dirk
