schlosser79 wrote: |
| Is it possible to do this with VAGCOM without clearing the memory? |
Yes, if a login is available.
| ...where is the login code located?... |
It's on the small plastic tag, which usually isn't there anymore. VW doesn't provide any physical documentation; everything is online.
Edit: Could someone please provide the part number for the "new" AI? It seems like it might be the wrong one!
