17-08-2009, 16:08 Subject: RKA Retrofit for 1K0 907 379 AC |
Can the RKA (Rear Collision Avoidance) system be easily retrofitted to this ABS/ESP system using buttons and coding?
Code: | Adresse 03: Bremsen/ABS Labeldatei: RKS\1K0-907-379-MK60-F.LBL
Teilenummer SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Bauteil: ESP FRONT MK60 0101
Codierung: 0021121
Werkstatt #: WSC 01279
| Transparency, Teamwork
Translated on 31-08-2026, 7:13.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
17-08-2009, 21:29 Subject: RKA Retrofit for 1K0 907 379 AC |
If no one else responds:
Have you tried the encoding yet?
If not: First, try encoding.
If that works: Simply plug a yellow wire into the ABS control unit and connect it to the car body. If you then hear a "ping" from the instrument cluster, I would suggest test driving it. If it works, extend the yellow wire into the interior.
Good luck!
Profile PM Garage |
18-08-2009, 8:09 Subject: RKA Retrofit for 1K0 907 379 AC |
For the Passat, it's "add 2048".
I vaguely remember that in golf, it's not about *setting* a bit, but rather *clearing* it, meaning subtracting something.
Unfortunately, I can't find that guide anymore. I got it from some forum, maybe something like MT or Doppel-Wobber, or something similar.
m; Transparency, Teamwork
Translated on 31-08-2026, 7:14.
Profile PM Garage |
18-08-2009, 8:21 Subject: RKA Retrofit for 1K0 907 379 AC |
dieselmartin wrote: | | I vaguely remember that in golf, it's not about _setting_ a bit, but rather _clearing_ it, meaning taking something away. |
You're absolutely right, Martin! MfG. Michael
Translated on 31-08-2026, 7:15.
Profile PM Garage |
Profile PM Garage |
25-01-2012, 0:03 Subject: RKA Retrofit for 1K0 907 379 AC |
WOW!!!
No switches!
Simply "re-encode" and then set the basic parameters to 042.
The golf club is currently diligently learning  . Transparency, Teamwork
Translated on 31-08-2026, 7:16.
Profile PM Garage |
22-02-2012, 18:17 Subject: RKA Retrofit for 1K0 907 379 AC |
Not that great.
Is the TCU coded for "Caddy," and does it not want to know anything about the RKA  ?
Profile PM Garage |
