Skoda Superb: Easy Entry Problem & Solution
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Braeuni
Post25-01-2012, 16:12    Subject: Skoda Superb: Easy Entry Problem & Solution Quote
I'm having a problem activating the easy entry function in my Superb 2.
If you set adaptation channel 60 in control unit 36 to 1 (i.e., enable), the seat will retract slightly when the door is opened (for exiting), and the backrest angle will change.
If I open the door again (to get in), the seat moves back a little.
When the engine is started, the backrest angle changes again, but the seat no longer returns to the saved memory position.
In German, a short way to say it is: "The seat only moves backward, never forward."
I've extracted the section for control unit 36 from the Autoscan data, as shown below (using version 11.11.1).
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 36: Seat adjustment for driver (J810)
Label file: 3C0-959-760.lbl
Part number SW: 3C8 959 760 A, HW: 3C8 959 760 A.
Component: Seat Memory. Part Number: H05 2601.
Revision: 00H05000
Encoding: 00003B
Operating number: WSC 12336 024 394758
VCID: 336E7313922E481
No error codes found.
"I'm also attaching a picture of the measurement blocks 1-6."
Despite "easy entry" being activated in stage 36, "easy entry" is not recognized for material number 6, and the "easy entry" function is inactive. In material numbers 4 and 5, the error message "not available" is displayed.
Can you help me? Is any further information needed?
Thank you for your efforts.
Braeuni.
Translated on 08-10-2026, 8:31.
Braeuni
Post02-03-2012, 19:24    Subject: Skoda Superb: Easy Entry Problem & Solution Quote
Hi!
Since the new update for the driver's seat system, the easy entry function is now working for me!
BrÀuni.
Translated on 08-10-2026, 8:34.
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts Skoda Cooking: Maggi Recipes & Car Kitchen Transmission, Chassis, Body & Interior
No new posts Skoda Daytime Running Lights: Best Options Transmission, Chassis, Body & Interior
No new posts Skoda Octavia 1.9: Specs, Problems, & More On-Board Diagnostics (OBD)
