chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
20-12-2011, 11:23 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Hello.
I'm having a problem with my T5 AXD. I've been hearing a noise coming from the air filter box (a dull thumping sound that varies with engine speed). When I accelerate, the thumping gets louder.
It's difficult to describe, but maybe someone else knows about this problem.
I found a video about this; what do you think of it?
http://www.youtube.com/watch?v=C1jAfeRnmRk
The preheating light isn't flashing for me, and the error memory is also clear.
Thank you, Chris.
A6 AFB
A6 BRE DPF
Translated on 31-07-2026, 20:49.
Joined: 04/12/2002 Posts: 18064 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
20-12-2011, 12:20 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Is the intake valve not closing properly? Are there any other unusual symptoms, such as white or gray smoke?
What does the idle speed control say in measurement block 13?
Translated on 31-07-2026, 20:50.
Profile PM WWW Garage |
chli1976 Profi-Schrauber
20-12-2011, 13:33 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
What does the error memory say?
I've experienced a similar knocking/rumbling sound coming from the air filter housing before. In my case, it was caused by worn camshaft lobes.
VCDS
Translated on 31-07-2026, 20:51.
mullemaus Guest
20-12-2011, 14:22 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
I've already experienced a knocking/rumbling sound coming from the air filter box before. In my case, it was due to worn camshaft lobes.
Ditto  .
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
20-12-2011, 14:43 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
chli1976 wrote: |
I've already experienced a knocking/rumbling sound coming from the air filter box before. In my case, it was due to worn camshaft lobes. |
I agree. There should also be a loss of power at lower RPMs. The one in the video has more problems; something is leaking somewhere, and a healthy engine would immediately stall if you close the fuel shut-off valve.
reflexsilber met.
Translated on 31-07-2026, 20:52.
Profile PM Garage |
chriskross Blaumann
20-12-2011, 17:21 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
The error memory is clear, and you were right, it's the timing belt. There are noticeable grooves on the camshaft in two places.
Even during the idle speed control test, nothing unusual was observed.
"For some time now, I've also been having the problem that it takes a very long time to start the car in the mornings, but only when it has been turned off overnight."
What do you think might be the cause of this? Could it be related to the Northwest (NW) area, or are the PDE seals also damaged?
I just hope I can get the tools; it's crazy how much you need for everything.
A6 AFB
A6 BRE DPF
Translated on 31-07-2026, 20:53.
RedR32 Schrauber
20-12-2011, 19:22 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Great gear construction, or what?
It might be a good time to replace the positive displacement (PD) seal rings now as well. However, that's quite a bit of work if you want to do it properly.
reflexsilber met.
Translated on 31-07-2026, 20:55.
Profile PM Garage |
chriskross Blaumann
20-12-2011, 19:28 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Sure, great design, a real masterpiece from the VW engineers.
It seems that it's not uncommon for the NW units to break down  .
A6 AFB
A6 BRE DPF
20-12-2011, 20:45 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
If it's difficult to start, be sure to replace the sealing rings of the PDE (positive displacement element).
VCDS
Translated on 31-07-2026, 20:56.
chriskross Blaumann
23-12-2011, 8:25 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Four out of the five glow plugs were also defective, but the engine control unit did not detect this. There were no error codes.
That should normally be stored in the error memory, right?
A6 AFB
A6 BRE DPF
23-12-2011, 9:40 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
No, the AXD engine is actually the Euro 3 version without a DPF (Diesel Particulate Filter), EGR cooler, electric EGR valve, and all that stuff.
Glow plugs are only monitored from the Euro 4 standard onwards.
Translated on 31-07-2026, 20:57.
Profile PM Garage |
chriskross Blaumann
20-02-2012, 19:47 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Hello, after replacing the water pump, hydraulic components, needle bearings, rocker arms, and all pressure plate seals, the car is running again.
Now I have a problem: there's diesel in the engine oil, and quite a lot of it.
After approximately 3000 km, I had almost 4 liters of diesel in the oil  .
I've now also replaced the tandem pump. It was only producing 4 bar at 1500 RPM. With the new pump, I'm now getting between 8 and 9 bar at 1500 RPM.
However, unfortunately, after just 2 days, I already have about 0.5 to 0.75 liters of diesel in the oil again.
Could the sealing ring have been damaged during the installation of the power distribution element (PDE)? It's also possible that the control unit is still defective.
Is there a way to check if the seals are in good condition?
Thank you, Chris.
A6 AFB
A6 BRE DPF
Translated on 31-07-2026, 20:58.
Octavia_4x4 Schrauber
20-02-2012, 23:12 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Diesel fuel in the oil can definitely be caused by damaged piston ring seals! You should not continue driving like this, as it will wash the oil out of the cylinder bores.
Translated on 31-07-2026, 21:00.
chriskross Blaumann
21-02-2012, 16:53 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
Why were only 4 production facilities expanded?
Translated on 31-07-2026, 21:01.
Profile PM Garage |
chriskross Blaumann
21-02-2012, 17:13 Subject: T5 AXD: Rattle in Airbox - Diagnosis & Fix |
oops, I misspoke; of course, all five.
A6 AFB
A6 BRE DPF
