Urgent Diesel Piston Needed
kg60
Post06-04-2003, 15:55    Subject: Urgent Diesel Piston Needed Quote
Hi.
'Does anyone happen to know the length of a 1.9 diesel engine with a bore of 79.5 mm and a stroke of 95.5 mm?'
Best regards, KG60.
Translated on 17-07-2026, 12:59.
Wolfgang, syncro16
Post07-04-2003, 13:29    Subject: Urgent Diesel Piston Needed Quote
Hello KG60,
There are various lengths; here are a few examples:
AAZ 1Z AHU AFN engines have a 144 mm [dimension].
1Y has a diameter of 150 mm.
Hello.
Wolfgang.
Translated on 17-07-2026, 13:00.
kg60
Post08-04-2003, 13:33    Subject: Urgent Diesel Piston Needed Quote
Hi.
I was just thinking about the high building.
I'm building a 16v turbo engine and it has a high-compression block with an 81mm bore and a diesel crankshaft.
'Now, if I install the 144cc pistons and connecting rods, I still have a good 11mm of clearance before reaching top dead center!'
That's why the pistons in a diesel engine have to be designed completely differently.
And I think they would have been able to handle the power just fine.
Best regards, KG60.
Translated on 17-07-2026, 13:01.
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Connecting rod of a ship's diesel engine Diesel Engine Technology
No new posts AFN Engine: Head Gasket, Connecting Rod Issues? Diesel Engine Technology
No new posts Torque specifications for crankshaft/connecting rod (CBBB) Diesel Engine Technology
No new posts Urgent!!! Difference between AAT models 92-95 Diesel Engine Technology
