2006 Touran central locking not always working
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Stummel
Post22-04-2012, 16:39    Subject: 2006 Touran central locking not always working Quote
My parents have a 2006 Highline Touran.
The problem is that sometimes the right door doesn't unlock when you use the central locking system. Simply pressing the 'unlock' button again doesn't help... you have to lock it and then unlock it again. What happens when you manually lock something, and what happens when it locks automatically?
As long as you only close 'on' and 'to', there will be no errors in the memory. If the device enters 'Safe' mode (meaning it locks itself because it was unlocked, but no door is opened), the following error message appears:
Address 52: Door electric, passenger side. Label file: DRV\1K0-959-702-MIN2.lbl
Part number: 1T0 959 702 B
Part: Door seal 024 2301
Encoding: 0000245
Operating number: WSC 01324 785 00200
VCID: 37527BE63FDD
2 error codes found:
00097 - Motor for central locking (safe); passenger door (V162).
012 - Electrical fault in the circuit - Intermittent.
00929 - Door lock module for central locking, passenger side (F221)
008 - Implausible signal - Sporadic.
The wiring in the door and leading to the door is okay (all properly connected). In 50% of cases, it works to unlock the door (of course, with the mechanism removed, it works 100% of the time). The cables also look good, so nothing is pinched or otherwise damaged.
The question is, what should I do now? Should I replace the lock? Rewiring needed? Or is the motor in the detached house new (does that have anything to do with it?)
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 55 56 62 69 72
76 77
Vehicle Identification Number: WVGZZZ1TZ6W2cccc1 Mileage: 96290 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: Intermittent communication error 1000.
19-Diagnostic interface -- Status: Error 0010.
Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Co-driver. -- Status: Error 0010.
55-Beam angle adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking Assist -- Status: OK 0000
'EDIT MOD: Log truncated'
Translated on 05-07-2026, 19:47.
Post22-04-2012, 22:12    Subject: 2006 Touran central locking not always working Quote
The question now is what to do? Should I replace the lock? Rewiring? Or new motor for the detached house? (Does that have anything to do with it??)
I would guess it's the lock, because the problem only occurs with the "safe."
Possibly a safety lever (see below). Arrow) broken, 2nd motor (only for safety function) defective, cold solder joints or similar.
PS: Please pay attention to punctuation in the future. icon_wink.gif
 Türschloss
 File size:  93.27 KB
 Viewed:  22664 times
Translated on 05-07-2026, 19:53.
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Brake Pad Wear Light Always On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Astra 2006: Read VC Unit Data On-Board Diagnostics (OBD)
No new posts Es muß nicht immer die Kurbelwellenschraube sein! Diesel Engine Technology
No new posts Golf 4 won't start? Troubleshooting guide On-Board Diagnostics (OBD)
No new posts 1Z Still Not Working: Troubleshooting Guide Diesel Engine Technology
