Brake System Coding Removed
AELfahrer
1997 Audi A6 Avant
Post08-08-2012, 22:02    Subject: Brake System Coding Removed Quote
has installed an Audi A4 8E GRA with a FIS (Instrument Cluster Information System). Now there is a problem with the brake control unit, as the operating number and the coding are missing. How can I solve this problem?
Best regards, Andre
Address 03: Brakes Label file: RKS\8E0-614-517.LBL
Part number: 8E0 614 517
Part and/or Version: ABS/ESP front 1726
Encoding: 00000
Operating Number: WSC 00000
VCID: E5CE4B177F7A671
2 errors found:
00778 - Steering Angle Sensor (G85)
66-10 - Reconciliation not performed - Sporadically
01044 - Incorrectly coded control unit
35-00 - -
Post08-08-2012, 22:57    Subject: Brake System Coding Removed Quote
1. Create a vehicle-specific login and enter it.
2. Create and enter vehicle-specific coding
3. Conduct reconciliation by the LWS
VCDS shows you how login and coding are generated.
It is possible that the ESP lamp may not turn off after these actions. Then you'll also need to drive a bit more on curvy roads and country roads. icon_wink.gif
AELfahrer
1997 Audi A6 Avant
Post08-08-2012, 23:01    Subject: Brake System Coding Removed Quote
TDI-GTI-4-Motion wrote:
1. Create and enter a vehicle-specific login
It is possible that the ESP lamp may not turn off after these actions. Then you'll also need to drive a bit on curvy roads and country roads. icon_wink.gif
Thank you for your response.
1. and 2. have already been attempted. Still, it's not working. Especially, the WSC is also missing.
Greetings
Post08-08-2012, 23:09    Subject: Brake System Coding Removed Quote
So, he logs in, but doesn't code?
WSC is completely irrelevant.
AELfahrer
1997 Audi A6 Avant
Post08-08-2012, 23:13    Subject: Brake System Coding Removed Quote
So, wenn ich mich mit dem Code angemeldet habe und dann den Code eingebe, erkennt er ihn erst dann. If I remove the control unit and then re-install it, the code will be 00000 again.
Greetings
Post08-08-2012, 23:20    Subject: Brake System Coding Removed Quote
The 3 mentioned points must be done at the same time. The coding will only be permanently saved once the reconciliation from the lumbar spine has been completed.
You must not leave the STG in the middle!
DieselBär30x
Avatar-DieselBär30x
Hello everyone!
...WSC is completely unimportant.
That's not quite right!
There are STGs where the WSC cannot be 000...
Coding or any other access will then be prevented.
Whether this is the problem with this brake system, I don't know.
Simply enter a fantasy number for the VCDS setting for the WSC, save it, and then try again.
Best regards from Munich!
Post08-08-2012, 23:22    Subject: Brake System Coding Removed Quote
DieselBär30x wrote:
Hello everyone!
OK, I've never done that before.
Okay, hier ist die Übersetzung:
"Bitte geben Sie Ihren Namen und Ihre Adresse an. {NAME} {ADRESSE}
Bitte geben Sie Ihre E-Mail-Adresse an. {EMAIL}
Bitte geben Sie Ihr Geburtsdatum an. {GEBURTSDATUM}
Bitte geben Sie Ihre Telefonnummer an. {TELEFONNUMMER}
Ich bin {ALTER} Jahre alt.
Ich bin {GESCHLECHT}
Ich bin {NATIONALITÄT}
Ich bin {BERUFS}
Ich bin {HOBBY}
Ich bin {INTERESSEN}
Ich bin {FAMILIENZUSTAND}
Ich bin {HAUSTIER}
Ich bin {FAHRZEUG}
Ich bin {HAUSHALTSGRÖSSE}
Ich bin {WOHNORT}
Ich bin {ORT}
Ich bin {LAND}
Ich bin {POSTLEITZAHL}
Ich bin {STRASSE}
Ich bin {HAUSNUMMER}
Ich bin {FLUR}
Ich bin {ETAGE}
Ich bin {TELEFON}
Ich bin {TELEFON}
Ich bin {TELEFON}
Ich bin {TELEFON}
Ich bin {TELEFON}
AELfahrer
1997 Audi A6 Avant
Post08-08-2012, 23:29    Subject: Brake System Coding Removed Quote
Okay, here's the translation:
so, again for the really dummies
1. First, log in using the vehicle-specific code.
2. Coding with vehicle-specific code WSC on 12345
3. Login with 40168 for default settings
4. Default Settings LWS
5. Leave the control unit. Turn off the ignition and then start the engine and take a test drive.
Post08-08-2012, 23:32    Subject: Brake System Coding Removed Quote
5. Leave the control unit. Turn off the ignition and start the engine again
Exactly, a test drive only if the ESP light remains on.
AELfahrer
1997 Audi A6 Avant
Post08-08-2012, 23:35    Subject: Brake System Coding Removed Quote
I will get back to you tomorrow.
Greetings
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock code adjustments, brake control unit, ESP, Mark 60 Transmission, Chassis, Body & Interior
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts STG-Codierung Diesel Engine Technology
No new posts Codierung MSG AKN On-Board Diagnostics (OBD)
