pa-mm6 Blaumann
30-12-2006, 21:50 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Hello.
I bought an oil temperature sensor for my TDI (ARL). The instructions say that you need to remove a blind screw from the oil filter flange and replace it with the screw that comes with the sensor. However, I can't find a blind screw on my flange. Is this normal, or are there no screws on some models?
Certainly. Here's the translation:
"Thank you very much."
Best regards.
Thomas Pflieger.
Audi SQ5 8R Cvub
Translated on 27-08-2026, 19:41.
Profile PM Email |
31-12-2006, 0:47 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Hi.
When you are standing in front of the motor, there should be an Allen screw inserted on the left side.
The filter flange is the same for all diesel engines.
Translated on 27-08-2026, 19:42.
Profile PM Garage |
pa-mm6 Blaumann
31-12-2006, 5:12 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Hello.
I thought so too, but unfortunately, there's no screw there that you can remove. There's a small protrusion, but there's no screw in it, even though it might look like there is. I checked on my ARL model (year 2002) and on an ASZ model (year 2003). According to AKTE, there are 3 screws visible on the flange on the right side, one of which is the turbo supply line. Could it be that they are located on the right side? It's really difficult to see. Does anyone have a photo?
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 27-08-2026, 19:43.
Profile PM Email |
02-01-2007, 12:27 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
pa-mm6 wrote: | | Unfortunately, there is no screw inside that can be unscrewed. | Although there is a small protrusion, there is no screw in it, even though it may appear that way.
I'm experiencing the same problem with my Polo, even though it has a different (more compact) oil filter housing than the one installed in the G4 platform.
The screw-saving method seems to be working }.
Translated on 27-08-2026, 19:44.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
02-01-2007, 14:29 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Okay, I also looked at that Golf IV ASZ and thought it was weird!
Translated on 27-08-2026, 19:45.
02-01-2007, 16:03 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
What do you mean by "saving screws"?
Did they use a different mold where there's no flange at all for the screw, or did they just not drill and tap the thread?
Regarding (2), one could still do some more work  .
Profile PM Garage |
02-01-2007, 16:17 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
This is version two, and I have done post-processing!
Translated on 27-08-2026, 19:46.
02-01-2007, 16:18 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
dieselmartin wrote: | Did they use a different mold, where there is no flange at all for the screw, or "just" the thread wasn't drilled and cut?
Regarding (2), it might be possible to still make some improvements  | .
It's probably closer to 2.
However, as far as I know, common adapters are designed for flat sealing surfaces to accommodate washers. In contrast, the suggested flange shows a rough cast aluminum surface.
And if, when reworking, you can't achieve exactly 90° between the thread and the sealing surface, you'll have a constant oil leak (as long as there's anything left in the tank).
Translated on 27-08-2026, 19:47.
Profile PM Garage |
pa-mm6 Blaumann
02-01-2007, 18:48 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Hi everyone.
I heard from another forum that there's supposed to be a Y-adapter for the oil pressure sensor. Is that true? That would be really great! You could just unscrew the oil pressure sensor, screw in the adapter, and then screw the sensors into the two openings.
Best regards.
Thomas.
Audi SQ5 8R Cvub
Translated on 27-08-2026, 19:48.
Profile PM Email |
pa-mm6 Blaumann
03-01-2007, 23:03 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Oh man, I can't find this part anywhere. Does anyone happen to know where I can get one?
Audi SQ5 8R Cvub
Translated on 27-08-2026, 19:49.
Profile PM Email |
Hojo-Hörnchen
23-01-2012, 12:40 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Hi everyone,
1.9 TDI ASZ engine, Seat Ibiza 6L, first registration 2004.
Is there an oil temperature sensor located on the right side, near the oil filter housing?
It seems to be a plug with a single-pole cable.
Can the temperature be read via OBD? In the module-specific data of the engine control unit (MSG), it always only shows 0 degrees  .
"Thank you."
Jochen.
| Description: |
| File size: |
306.92 KB |
| Viewed: |
940 times |
| Description: |
| File size: |
440.56 KB |
| Viewed: |
1269 times |
| Description: |
| File size: |
520.38 KB |
| Viewed: |
3151 times |
Translated on 27-08-2026, 19:50.
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
23-01-2012, 12:52 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Hojo-Hörnchen wrote: | Hi everyone,
Can the temperature be read via OBD? In the module-specific data of the engine control unit (ECU), it always only shows 0 degrees .
"Thank you."
Jochen |
It's a pressure sensor. The oil temperature might be readable in the combination instrument control unit (MIB), using the sensor located in the oil pan.
reflexsilber met.
Translated on 27-08-2026, 19:51.
Profile PM Garage |
Hojo-Hörnchen
05-02-2012, 20:14 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Thank you for the answer  .
When it gets warmer, I need to investigate that more closely. Soon, I have an oil change scheduled, and then I can also look underneath to see if there's a sensor there  .
Translated on 27-08-2026, 19:52.
Hojo-Hörnchen
26-08-2012, 20:32 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
I took a closer look the other day... the car doesn't have an oil temperature sensor located on the bottom of the oil pan  .
The recess is there, and there are 3 threads, but nothing else.
Seat Ibiza 6L Cupra TDI.
BUK und GUC. 136.000 Km.
RedR32 Schrauber
27-08-2012, 20:55 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
"Thank you."
Jochen |
Quote: | | The car does not have an oil temperature sensor located at the bottom of the oil pan | .
Yes, with Seat, the long-life service was sometimes only introduced later, which partially explains the situation.
I'm sorry that it's not working.
reflexsilber met.
Translated on 27-08-2026, 19:53.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
28-08-2012, 12:43 Subject: Oil Filter Flange TDI PD ARL ASZ Screw for Oil Temp. |
Translated on 27-08-2026, 19:54.
