Joined: 04/12/2002 Posts: 18099 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
25-02-2010, 19:12 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
In my premium product, the mechanical component of the EGR valve failed after approximately 63,000 km.
The EGR valve consists of a type of throttle valve that is operated via a shaft and two sets of gears.
Ironically, the least stressed gear, which is located on the drive shaft of the actuator motor, is made of metal. The rest is made of plastic and suffers from tooth wear, even though the valve itself operates smoothly.
Clearly, the wear and tear is due to incorrect material selection or inadequate sizing.
- Is there an improved EGR valve with a metal wheel?
- Is 03G131501Q the latest revision level?
- Is there a free replacement available from the manufacturer of the premium product, as there appears to be an obvious design flaw?
Translated on 02-08-2026, 12:46.
Profile PM WWW Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
25-02-2010, 21:13 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
If this issue isn't properly addressed, you could end up with significant defects that a competent workshop would likely replace under warranty.
Oops... or the warranty has expired  .
reflexsilber met.
Translated on 02-08-2026, 12:48.
Profile PM Garage |
25-02-2010, 22:35 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
EZ 10/2007 = no warranty.
bakkano Schrauber
26-02-2010, 10:15 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
Hello Rainer.
Visit an AMAG dealer near you and request a goodwill gesture/favour.
Soweit ich weiss gibt es 70% auf das Material im 3. Year.
If you provide me with the vehicle identification number (VIN) and mileage, I can also check it for you.
Sascha.
Translated on 02-08-2026, 12:49.
26-02-2010, 10:28 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
The cross-brother BMR received a new valve in 2008.
03G131501 to 03G131501P.
How did you notice the defect?
Translated on 02-08-2026, 12:50.
Profile PM Garage |
26-02-2010, 11:16 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
dieselmartin wrote: |
How did you notice the defect? |
Pmax ~ 35 horsepower
Fortunately, it's at least always "too."
@ bakkano : Thanks, DM!
| Description: |
| Mechanik AGR Ventil (elektrische Ansteuerung) |
| File size: |
145.75 KB |
| Viewed: |
52941 times |
Translated on 02-08-2026, 12:51.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
26-02-2010, 12:01 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
No wonder with all the plastic  . Wouldn't it be easier to disable the AGR (Active Grille Roller) via software?
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
26-02-2010, 12:22 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
T3Surfer wrote: | | Wouldn't it be easier to disable the AGR (Automatic Gear Recognition) using software? |
Yes. However, I often have many short trips in a row, and without the EGR system, this makes it difficult for the DPF to regenerate properly because the engine doesn't get up to temperature easily, and the exhaust gas temperature is also lower.
Translated on 02-08-2026, 12:52.
26-02-2010, 13:18 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
Quote: | | Yes. However, I often have many short trips in a row, and without the EGR system, it's not good for the DPF regeneration because the engine hardly gets warm enough, and the exhaust temperature is also lower. |
Aha  . That's why! I understand; it's the same with my car. If the EGR valve is disconnected, it barely warms up in city driving when it's below freezing. Short trips unfortunately ruin all sorts of things  .
Translated on 02-08-2026, 12:53.
RedR32 Schrauber
04-03-2010, 22:32 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
Hi Rainer, what did you do now, buy a new one or something? That's really annoying, isn't it  ?
reflexsilber met.
Translated on 02-08-2026, 12:54.
Profile PM Garage |
05-03-2010, 8:40 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
I ordered the 03G131501Q part relatively cheaply from a general parts supplier instead of from the overpriced dealers. The cost was probably even lower than what Audi would charge with goodwill arrangements.
I'm going to check if the teeth are made of a more durable material or at least wider. It should arrive today.
11-03-2010, 23:02 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
It's also cheap plastic junk, and that's on an A6...
Translated on 02-08-2026, 12:55.
RedR32 Schrauber
12-03-2010, 0:03 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
reflexsilber met.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
12-03-2010, 8:21 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
It was probably possible to manufacture it even more cheaply  .
Translated on 02-08-2026, 12:56.
12-03-2010, 9:07 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
matthiasTDI96 wrote: | It was probably possible to manufacture it even more cheaply  | .
See SMC intake manifolds, SMC oil pans...
And the perverse thing is, you can justify it so nicely with "weight and thus fuel consumption reduction"... or rather, put a positive spin on it.
And what the SMC manifolds hold can be seen in the swirl flaps of the intake manifolds  .
also with a plastic funnel.
Profile PM Garage |
RennDiesel Blaumann
14-03-2010, 18:26 Subject: 2.0 TDI AGR Valve: Faulty & Replacement Guide |
What is SMC? Does it stand for Sheet Metal Compound?
Translated on 02-08-2026, 12:57.
