Front Wheel Drive: The Ultimate Guide
raddocki
2011 Seat Alhambra
Post24-10-2012, 19:43    Subject: Front Wheel Drive: The Ultimate Guide Quote
Hi everyone.
My steering feels quite vague, even with the 225-series tires.
Now I've tried spinning the wheel, and I noticed that it has a "loose" feel.
So, if I sit directly in front of the wheel and push it towards the wheel arch (both top and bottom), I can feel it move about 1-2mm.
You can hear it too.
I experience the same issue when I touch and move the wheel on the sides.
What could that be?
Wheel bearings?
Tie rod?
Ball joint?
"Addendum:"
Shock absorbers, springs, strut mounts, sway bar links, stabilizer bar bushings, rubber bushings for control arms, ball joints, and tie rod ends have already been replaced throughout the year.
Therefore, I suspect it's more likely to be a tie rod or a wheel bearing.
I don't want to exchange both, but I don't want to end up looking foolish icon_biggrin.gif.
Translated on 15-09-2026, 13:06.
Karma: +1353 / -0   Thank you, like it!
Post24-10-2012, 21:55    Subject: Front Wheel Drive: The Ultimate Guide Quote
Do you hear any running noise besides the normal sounds of the game, for example, when turning? That could indicate a faulty wheel bearing.
What kind of vehicle are we talking about?
Translated on 15-09-2026, 13:08.
raddocki
2011 Seat Alhambra
Post24-10-2012, 21:57    Subject: Front Wheel Drive: The Ultimate Guide Quote
I don't hear any running noise, at least not any that I can detect.
No whistling, creaking, or cracking.
Even when I turn the steering wheel fully in one direction and then back in the other, I don't hear any noises.
Therefore, I'm not even sure if this is caused by the tie rod.
It's a Volkswagen Golf Variant (estate/wagon) with four doors.
Translated on 15-09-2026, 13:09.
Post24-10-2012, 22:17    Subject: Front Wheel Drive: The Ultimate Guide Quote
A faulty wheel bearing in the front will manifest as rumbling or grinding noises when turning.
If you feel the play in the wheel as described, then check carefully where it's coming from. Feel around the axle joint, the top of the shock absorber, the tie rod joint, etc.
Translated on 15-09-2026, 13:10.
raddocki
2011 Seat Alhambra
Post24-10-2012, 22:18    Subject: Front Wheel Drive: The Ultimate Guide Quote
Do you mean directly at the axial joint?
Translated on 15-09-2026, 13:11.
Post25-10-2012, 7:41    Subject: Front Wheel Drive: The Ultimate Guide Quote
If by "axial joint" you mean a joint in the driveshaft, then no.
If the wheel has excessive play as described, it's either due to a completely damaged wheel bearing (which is why I asked about the typical noises associated with bearing failure), or a loose or worn connection in the wheel suspension. However, you'll need to inspect these potential areas yourself. It's obviously easier to do this in a workshop on a lift, ideally with a testing device ("shaker plate").
Post25-10-2012, 8:53    Subject: Front Wheel Drive: The Ultimate Guide Quote
The tie rod is commonly referred to as an axial joint. I think that's what he's talking about.
Wheel bearings on a Golf 4 can be quite tricky. I've already had two instances where the bearings had excessive play, but were still running completely silently.
Translated on 15-09-2026, 13:12.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post25-10-2012, 10:49    Subject: Front Wheel Drive: The Ultimate Guide Quote
Is the shock absorber rod tilting too much?
reflexsilber met.
Translated on 15-09-2026, 13:13.
bloesch
Post25-10-2012, 15:50    Subject: Front Wheel Drive: The Ultimate Guide Quote
Wheel bolt?
Central screw for driveshaft?
Post26-10-2012, 22:00    Subject: Front Wheel Drive: The Ultimate Guide Quote
Take another look at the wobbly part, get under the car, and listen/feel to see where the play is.
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken Wheel Part: Get Help Now! Transmission, Chassis, Body & Interior
No new posts Drivetrain Issues? Troubleshooting Guide. Diesel Engine Technology
No new posts Drive Shaft Games: Fun & Education Transmission, Chassis, Body & Interior
No new posts Loose Steering: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
