Golf 5 clutch pedal stays down
chriskross
Post22-10-2012, 19:36    Subject: Golf 5 clutch pedal stays down Quote
Hi!
"I'm having a problem with my Golf 5 Plus 1.6 gasoline engine where the clutch pedal occasionally gets stuck in the down position. I have to pull it back up with my foot, and then it works normally again."
The error occurs approximately once when the "100" button is pressed.
What I've also noticed is that when pressing the pedal, you can hear a creaking sound coming from the transmission or the clutch slave cylinder.
I checked the cylinders, and everything is dry, including the hose.
Does anyone know this problem?
A6 AFB
A6 BRE DPF
Translated on 19-07-2026, 0:51.
DieselBär30x
Avatar-DieselBär30x
Post22-10-2012, 19:52    Subject: Golf 5 clutch pedal stays down Quote
Hi Chris!
Try searching for ":wink:clutch pedal"; there are plenty of relevant documents available to read about it. }
To start with, I would check the receiver cylinder first.
Best regards from Munich!
Translated on 19-07-2026, 0:52.
Post22-10-2012, 20:37    Subject: Golf 5 clutch pedal stays down Quote
In my opinion, these cylinders are only slightly better than a water pistol you'd find at a fairground.
I generally replace both master cylinders (unless it's a vehicle with a central release mechanism), or neither at all. Of course, you could also start by replacing the slave cylinder. However, the cost and effort of a second repair aren't worth it when the parts cost around €50-€60.
Additional costs.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 19-07-2026, 0:53.
chriskross
Post22-10-2012, 22:05    Subject: Golf 5 clutch pedal stays down Quote
Thank you for the tips, I will replace both. It's quite annoying when the pedal suddenly gets stuck at the bottom. I'm just glad they didn't skimp on quality with the accelerator pedals icon_biggrin.gif.
Best regards, Chris.
A6 AFB
A6 BRE DPF
Translated on 19-07-2026, 0:54.
Post22-10-2012, 22:17    Subject: Golf 5 clutch pedal stays down Quote
If possible, a few photos would be great. If you disassemble the parts, you'll understand what is meant by "water pistol." icon_wink.gif
chriskross
Post23-10-2012, 12:16    Subject: Golf 5 clutch pedal stays down Quote
I've replaced the two cylinders now; I'll keep an eye on it and see how it goes.
P.S. Replacing the master cylinder is not something for people with weak nerves icon_eek.gif.
A6 AFB
A6 BRE DPF
Translated on 19-07-2026, 0:55.
No new posts Doku Golf 1J1214, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motorraumschutz unten, Golf 5 Transmission, Chassis, Body & Interior
No new posts Golf ALH mit AG4 - Turbolader ausbauen von oben oder unten? Diesel Engine Technology
No new posts Knarzendes Kupplungspedal Golf IV TDI ASZ Transmission, Chassis, Body & Interior
No new posts Correction (oil change below) Diesel Engine Technology
