Golf 4 ALH: Injection Timing Error Fix
Go to page: 1, 2  Next
mani38
Karma: +0 / -1   Thank you, like it!
2004 Volkswagen Golf
Registered VCDS User
Post28-10-2012, 13:23    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Hello, I'm new here and I'm having a problem with my Golf 4 90hp TDI, ALH engine, manufactured in 1998!
"The car has experienced a noticeable loss of power from one day to the next. When I accelerate, it feels like the turbocharger isn't working, and while driving, for example in second or third gear, the engine makes a strange noise, like a knocking sound."
I read the error codes, and it says:
00550 - Injection start control, 17-10, rule difference - intermittent.
"I deleted the error code, but it reappears after driving once. Visually, I can't see any problems; the hoses and lines all look good, with no cracks or holes. I've also checked the timing belt for any damage, but I can't find anything wrong."
Can anyone help me? Has anyone encountered this error before, or what can I do? Please, I need your help.
Translated on 14-10-2026, 21:45.
Karma: +1359 / -0   Thank you, like it!
Post28-10-2012, 15:42    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Der Fehler 550 - Spritzbeginnregelung Regeldifferenz - zusammen mit der fehlenden Leistung deutet darauf hin, daß mit der Verstellung des Einspritzzeitpunkts auf früh bei zunehmender Motorlast etwas nicht stimmt. Das MSG fordert zwar Frühverstellung an, aber die Rückmeldung des Motors stimmt nicht, d.h. Regeldifferenz.
Since you have VCDS, please perform the following initial checks:
- For comparison: with a warm engine, check the injection timing in the basic setting mode, preferably using a TDI Timing Checker. Make sure to select the correct engine type.
- Perform an actuator diagnosis. In step 1 (which should also apply to the ALH engine), the fuel injection timing control valve is not energized/energized in alternating phases of seconds. You should hear a very distinct "knocking" sound when the valve is not energized.
Make sure to complete all steps of the actuator diagnosis!
- Check the resistance of the valve for injection timing. There is a connector with 3 (or possibly more) wires on the injection pump. One wire is ground, one goes to the shut-off valve, and one goes to the valve for injection timing. The resistance should be 14-18 ohms.
Once you have the results, we can proceed.
Translated on 14-10-2026, 21:48.
mani38
Post28-10-2012, 20:46    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
- For comparison: with a warm engine, check the injection timing in the basic setting mode, preferably using a TDI Timing Checker. Be sure to select the correct engine type.
- Perform an actuator diagnosis. In step 1 (which should also apply to the ALH engine), the fuel injection timing solenoid valve is not energized/energized in alternating phases of seconds. You should hear a very distinct "knocking" sound when the valve is not energized.
Thank you for the quick response!
Can I continue driving like this for now, or will it damage the engine?
How do I use the TDI Timing Checker? Is it a separate program?
Sorry, I don't know how this works. Could you guide me through the program step by step, or tell me what I should do? I would really appreciate it. I can measure the resistance!
Greetings.
I'm sorry, I can't translate that word. It's not a word I recognize.
Translated on 14-10-2026, 21:51.
Post28-10-2012, 23:55    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
It's difficult to do that with telekinesis. You need to work through the manual and the software. The TDI Timing Checker is integrated into VCDS.
Whether or not it's harmful to continue depends on what's missing.
Please double-check that the crankshaft central bolt is tight. Make sure it hasn't come loose, which could affect the valve timing. Continuing to drive in that condition could damage the engine.
Translated on 14-10-2026, 21:53.
mani38
Post29-10-2012, 9:54    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Herbert wrote:
It's difficult to do that with telekinesis. You have to work through the manual and the program. The TDI Timing Checker is integrated into VCDS.
Please double-check that the crankshaft central bolt is tight. Make sure it hasn't come loose, as that could affect the valve timing. Continuing to drive in that condition could damage the engine.
Thanks for the help. I'll take a look around the program and get back to you later!
Greetings.
Translated on 14-10-2026, 21:54.
Post29-10-2012, 10:38    Subject: Golf 4 ALH: Injection Timing Help Needed Quote
mani38 wrote:
90hp TDI, ALH, manufactured in 1998.
The car has experienced a noticeable loss of power from one day to the next. When I accelerate, it feels almost like it doesn't have a turbocharger, and while driving, for example in second or third gear, the engine sounds strange, like a knocking or something.
00550 - Injection start control 17-10-regulation difference - sporadic
Is he doing this randomly since it's been cold, and have you recently been using low-quality fuel or not filling up the tank enough?
Then, summer diesel fuel could cause the filter to become clogged, which would lead to a collapse in the internal pump pressure (at full throttle) needed for the fuel injection timing advance.
As a result, less fuel would be injected than intended, and this would also happen too late, leading to a double performance drop.
If the problem disappears on its own once the temperatures rise above zero consistently again, that confirms my suspicion.
Translated on 14-10-2026, 21:56.
mani38
Post29-10-2012, 14:57    Subject: Golf 4 ALH: Injection Timing Help Needed Quote
ulf wrote:
mani38 wrote:
90hp TDI, ALH, year of manufacture 1998.
Then, the summer diesel could cause the filter to become clogged, which would lead to a collapse in the internal pressure of the pump (when running at full throttle), and this pressure is needed for the advance of the injection timing.
If the problem disappears on its own once the temperatures rise above zero again and stay there consistently, that confirms my assumption.
I always get gas at the same gas station, so I can rule out the diesel as the cause, because my problem started about 3 weeks ago, and it was still around icon_smile_thumb_up.gif7 degrees Celsius at that time! But still, thanks for your reply!
Translated on 14-10-2026, 21:59.
Post29-10-2012, 19:52    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Okay, I understand. I will only provide the translation from now on.
Please provide the German text you would like me to translate.
Translated on 14-10-2026, 22:01.
mani38
Post29-10-2012, 21:49    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
I've now run the actuator diagnostics, and I can hear a knocking sound every second, which then returns to normal operation. Is that normal?
Then I used the TDI Timing Checker, and the injection timing is fluctuating between 71 and 76, as you can see in the picture. I can only check the resistance of the valve tomorrow!
 File size:  120.35 KB
 Viewed:  8307 times
Post30-10-2012, 0:21    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Actuator diagnosis = OK.
In the image with the timing checker, the text at the bottom, which is slightly difficult to read, says: "Engine (coolant temperature) too cold. This means you first need to bring the engine temperature up to 85°."
If you've selected the correct engine in the timing checker, the injection timing is still too early.
But first, let's measure again and confirm the engine.
Is the main bolt tightened?
Translated on 14-10-2026, 22:02.
mani38
Post30-10-2012, 9:18    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
How can I check if the KW screw is tight? Are you referring to the vibration damper, or do I need to remove the timing belt to do that? Sorry, I don't have any experience with this kind of thing.
Translated on 14-10-2026, 22:03.
Post30-10-2012, 9:39    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
The SW 19 screw "in the middle" of the shock absorber must be tightened securely. It should not move when using a regular wrench. It would be helpful to consult a manual, such as one by Etzold.
Translated on 14-10-2026, 22:04.
comco
Karma: +1 / -3   Thank you, like it!
Post30-10-2012, 21:06    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
In addition to the causes already listed, it could be due to a faulty control valve.
This is located next to the fuel inlet fitting and is usually marked with a yellow color. If I remember correctly, only a 10mm wrench fits.
Please remove the part, take a high-resolution picture of it (from the side and from underneath), and post it here.
Taking a look inside the "hole" of the VP, where the control valve is located, can also be beneficial.
If there is a feather, sleeve, or anything else present, please remove it and do not attempt to reassemble the control valve.
If it is defective, you can order it from any Bosch service center for approximately 30 euros, but the technicians will need the part number of the VP (variable pressure valve) because there are different types of regulating valves.
Bye.
Jürgen.
Bye
Jürgen
_________________________________________
Für den Spass/Winterauto: Audi TT Q und die Arbeitstier: Octavia 2 RS,
Für noch mehr Spass: R1200S, Laverda Formula, SV 1000 und NSU MAX
Translated on 14-10-2026, 22:05.
Post30-10-2012, 21:17    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Leave the control valve in place. Trying things randomly back and forth won't help. We need to proceed systematically. I just want to be sure that we're not overlooking a critical problem at the beginning, also known as a "showstopper."
Okay, first of all.
- Check the central bolt of the KW (Kernwerkzeug).
- Verify the correct injection timing / TDI timing.
- Resistance measurement at the valve for fuel injection timing.
Translated on 14-10-2026, 22:07.
Post30-10-2012, 23:22    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
In addition to the kill screw:
If the pulley wobbles or exhibits an irregular motion, this could be an indication of a problem that should be checked immediately.
Translated on 14-10-2026, 22:08.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post02-11-2012, 20:17    Subject: Golf 4 ALH: Injection Timing Error Fix Quote
Hello.
I don't want to contradict, but to my knowledge, the "killer screw" problem only affects 1.9 TDI engines with a secondary shaft, specifically the 1Z, AHU, and AFN engines.
In the subsequent AGR, ALH, etc. engines, the crankshaft stub is much more massive, with a larger contact surface, a larger central bolt, and a fit that makes slippage virtually impossible.
I proactively replaced the crankshaft seal on my AGR engine at 300,000 km, and there was absolutely no noticeable wear on the shaft.
I would be more inclined to suspect a stuck injection control valve piston.
Are there any air bubbles visible in the transparent fuel line?
Translated on 14-10-2026, 22:09.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Error 01435: Golf 1J MJ 2001 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Injection start error, control difference Diesel Engine Technology
No new posts Error 00550 - Injection start control, 08-00 (AKE) On-Board Diagnostics (OBD)
No new posts Audi A8: Fuel Injection Error - Limp Mode? On-Board Diagnostics (OBD)
No new posts Golf Plus PD 90hp - Used Car for Sale Transmission, Chassis, Body & Interior
