Engine Jerk with DPF: Causes & Solutions
Go to page: 1, 2, 3, 4, 5, 6  Next
Martininii
Karma: +24 / -1   Thank you, like it!
Post17-01-2013, 22:19    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Hello fellow diesel enthusiasts,
ich weiß nicht mehr weiter, bin wirklich schon derbe verzweifelt was mein VW Caddy, mit 1,9tdi BLS Motor, der werksseitig einen DPF besitzt. (0603/AGB). Ich war mittlerweile in 2 VW Werkstätten und jetzt in einer freien Werkstatt. KOne knows more.
Regarding the history:
The car accelerates weakly within a range of 1700-2300 rpm, which I don't think results in a significant loss of power, but then there's a jolt and the power seems to explode. In first gear, especially when giving it full throttle from idle, the acceleration is initially relatively smooth, but then suddenly the front wheels start spinning.
Die Fehlerdiagnose der ersten VW Werkstatt war: Turbolader! So wie der Wagen da war, habe ich ihn vom Vorbesitzer abgenommen und den Turbolader erneuert, der von einer Turbolader-Instandsetzungsfirma General überholt wurde. Also der Turbolader ist der Originale, nur mit neuem Innenleben. Ich habe von dieser Firma bis jetzt 3 Turbos instand setzen lassen und nie ein Problem gehabt. That's all there is to it.
After replacing the turbo, I'm still having the same problem! And on top of that, you can hear the turbocharger. Specifically, there's a loud whistling sound that suddenly disappears when the acceleration jerk is over. The power is definitely there, so maximum speed isn't an issue.
Here's what I did: When replacing the turbocharger, I re-tightened the intake manifold screws to the specified torque. All the screws could be tightened further. Was this already a mistake? I did this because there is a metal gasket underneath. During the removal of the turbocharger, it appeared that a channel had been leaking, as there was some black residue around the exhaust bridge/turbo channel (the turbo and exhaust bridge are one unit in this design!).
After visiting the first workshop, I was told that they had checked the boost pressure and inspected the vacuum hoses. Additionally, the mass airflow sensor (MAF) was defective. Consequently, the MAF sensor was replaced.
Also die erste Werkstatt nicht mehr weiter wusste, ging ich zu einer Anderen: Die meinten das der LLK kaputt sein soll. Ich habe mich da schon sehr gewundert, da ich das Turbosystem mit 0,8Bar selbst schon abgedrückt hatte, was dicht war. Naja dann habe ich eben den LLK ausgebaut und abdrücken lassen. DHe's gone. / He passed away. / He died.
In addition to the above, I removed the EGR valve, cleaned it, replaced the seals, tested its function using a laboratory power supply, and checked the throttle body that sits in front of it. When none of that helped, I disconnected the connector for the EGR valve (the EGR closes when there is no voltage applied). That didn't help either. Also, this valve, which you can only see from below, controls something. Shortly after starting the engine, you can hear its linkage clicking.
I checked the diaphragm by pulling and reattaching the hose while the engine was idling. Everything worked relatively quickly, without sticking or anything like that. I also manually moved the linkage, which worked perfectly fine.
I sealed the exhaust as best I could to try and identify any leaks in the exhaust system. It was only hissing from the clamp connecting the catalytic converter to the muffler. Up front, in the engine area, there's nothing visible, audible, smellable, or felt.
I sprayed the intake manifold with brake cleaner while it was idling.
Okay, so I'm coming from the third workshop. They replaced a vacuum hose that had been patched twice, removed the valve cover and checked the electrical wiring, tried another Mass Air Flow sensor (MAF) as a test, and pressure-tested the charge air system again.
I have also replaced the pressure transducer (turbocharger control) and differential pressure sensor.
So und nun? I'm at my wit's end.
Is there anything else I can do that might help me identify the problem? The fact that this isn't normal is shown by a similar Caddy with 130,000 kilometers on it. Mine now has 170,000 kilometers.
If needed, I can record a video demonstrating the acceleration behavior.
Translated on 08-08-2026, 17:48.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post17-01-2013, 22:43    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Hi there. Do you have VCDS? If so, use it. First, create a full system scan.
Clear any self-generated errors (signal errors), then run the test again and read the results.
Then check the measurement values. There should be a label file for your MSG device; this data can be used to evaluate the current state.
"Edit: At 170,000 km, the DPF (Diesel Particulate Filter) might be completely full of ash, and cleaning or, better yet, replacement may be necessary. You can also read out the fill level."
reflexsilber met.
Translated on 08-08-2026, 17:54.
Martininii
Post17-01-2013, 22:56    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Thank you for your reply.
No, I don't own such a valuable tool. I obtained the license in a different way.
From your response, I gather that such a log is essential?
If so, is there anything I should be aware of? For example, who could I contact for help in interpreting such information?
I know that my description above sounds quite amateurish, but I tried to describe it as best as I could.
The only tool I have is CarPort, but I don't think it will be useful!
EDIT Are you from Bad Lobenstein? I'm from Tanna. Could we possibly meet up sometime to have errors read out, etc.?
Translated on 08-08-2026, 17:55.
Post17-01-2013, 23:11    Subject: Engine Jerk with DPF: Causes & Solutions Quote
It would be useful to have a log that includes the actual air mass, the target boost pressure, and the actual boost pressure.
It is also necessary to check if there is sufficient vacuum reaching the VTG (Variable Turbine Geometry) control unit of the turbocharger and that the vacuum system does not have any leaks.
Background: If there is insufficient vacuum, the VTG (Variable Turbine Geometry) nozzle on the turbocharger will not fully close, and the turbocharger will only build up pressure very slowly. However, once a certain exhaust gas flow rate is reached, this becomes sufficient, and the performance increases abruptly.
Translated on 08-08-2026, 17:57.
RedR32
Avatar-RedR32
Post17-01-2013, 23:16    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Meeting.
Sure, no problem. Please send it via private message.
reflexsilber met.
Translated on 08-08-2026, 17:58.
Martininii
Post17-01-2013, 23:18    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Bitte schreib mir eine PN: Ich kann erst ab dem 5. Contribution...
Then we'll see what happens next!
Post17-01-2013, 23:50    Subject: Engine Jerk with DPF: Causes & Solutions Quote
and read here:
/viewtopic.php?t=10810&highlight=vintage+setting
and:
/viewtopic.php?t=26673&highlight=vintage+clothing
Then create the corresponding log and post it here. Don't modify anything in the VTG beforehand.
Bold assumption: The VTG (vehicle tracking system) is malfunctioning or incorrectly configured.
If so, is there anything I should be aware of? For example, who could I contact for help in analyzing something like that?
In the medium term, you should consider getting a VCDS device. Diagnostic tests and troubleshooting can already take up a lot of time. It's always tricky when you're using borrowed equipment.
Edit: Oops, I just realized that you're getting really competent help. Then nothing can really go wrong anymore. icon_wink.gif
Translated on 08-08-2026, 18:00.
Martininii
Post18-01-2013, 0:00    Subject: Engine Jerk with DPF: Causes & Solutions Quote
"Yes, I'll definitely buy a diagnostic tool. However, I don't want the cheapest one that only works with vehicles using CAN bus technology; I also want to be able to diagnose older cars. Right now, my Caddy is really draining my wallet..."
Before I continue writing, I'm waiting for the log file, which hopefully will provide some insight at the end.
Translated on 08-08-2026, 18:01.
Post18-01-2013, 9:18    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Do you have the BV39 installed?
At least ours does.
Even though the software in the engine control unit (ECU) might be slightly different, I can help you with comparative data.
Greetings.
Translated on 08-08-2026, 18:02.
Martininii
Post18-01-2013, 14:12    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Yes, that's correct, I have the BV39 installed, as you can see in the picture. Thank you for the offer!
 KKK BV39 Turbolader
 File size:  198.29 KB
 Viewed:  7896 times
Translated on 08-08-2026, 18:03.
RedR32
Avatar-RedR32
Post20-01-2013, 23:13    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Hello, somehow the car sounds very muffled and booming.
Ash mass balance.
819 RPM Motor speed (G28)
62.0 Ash content
21.6 liters - consumption since regeneration.
240 km distance since regeneration.
VCDS indicates that the DPF is at 60% full, and I agree.
Point 1: The user wants to clean the DPF (Diesel Particulate Filter).
What do you think about the log? I'm initially leaning towards point 1 before opening new projects.
In the log, "Stop" or "Continue" was recorded, which is a shame because it's not very clear. Is it possible to mark this during recording?
We were always accelerating at full throttle.
LOG-01-011-010-xxx.CSV
 File name:  LOG-01-011-010-xxx.CSV
 File size:  29.91 KB
 Downloaded:  553 times
reflexsilber met.
Translated on 08-08-2026, 18:04.
RedR32
Avatar-RedR32
Post20-01-2013, 23:21    Subject: Engine Jerk with DPF: Causes & Solutions Quote
RedR32 wrote:
In the log, "Stop" or "Continue" was pressed, which is a shame because it's not clearly visible. Is it possible to mark this during recording?
Yes, at 100% throttle position.
reflexsilber met.
Translated on 08-08-2026, 18:06.
Post20-01-2013, 23:49    Subject: Engine Jerk with DPF: Causes & Solutions Quote
The DPF should be clean and functioning properly before you start working on the turbo..., although that would be a setback. In this case (warranty on the TL), I would start with the DPF.
Translated on 08-08-2026, 18:07.
Martininii
Post21-01-2013, 1:21    Subject: Engine Jerk with DPF: Causes & Solutions Quote
I'm going to start by looking at the DPF now. Somewhere along the way, I was hoping it would be clogged, because that would actually be a simpler repair.
I'm glad I got to meet RedR32 today, and I don't know how to properly thank him. (It was a lot of fun.)
I'm just a little disappointed that none of the three workshops identified the problem.
Martininii
Post23-01-2013, 19:11    Subject: Engine Jerk with DPF: Causes & Solutions Quote
The particulate filter has now been cleaned. It was rinsed several times with hot water.
The dull rumbling sound was caused by the fact that the exhaust temperature sensor temperature sensor, located below the particulate filter, was not screwed into its thread at all. It was just hanging there...
The whistling was therefore not as loud as RedR32 himself had heard it.
Overall, this issue is still present! However, the cleaned particulate filter hasn't been registered in the software yet. But I don't think that should have any impact, right?
That exhaust temperature sensor thing is making me suspicious. Shouldn't the software have detected that?
Translated on 08-08-2026, 18:09.
Post23-01-2013, 20:39    Subject: Engine Jerk with DPF: Causes & Solutions Quote
Martininii wrote:
The thing about the exhaust temperature sensor makes me suspicious. Shouldn't the software have noticed that?
Yes. Is the software up to date? What version of the software are you actually using?
Flushed several times with hot water.
Exactly how? You don't need to start with a watering can for this; I recommend using a 3/4" hose with sufficient flow rate.
When cleaning the DPF, the success of the process should be determined by measuring the differential pressure (before and after), and the ash mass should be adjusted accordingly.
Immediately before dismantling and cleaning, the DPF must be forced to regenerate because otherwise oil residues and soot will prevent the ash from being flushed out.
Translated on 08-08-2026, 18:11.
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - AGR errors and jerking during acceleration when in ... Diesel Engine Technology
No new posts Audi A1 1.6 TDI: Jerking During Acceleration Diesel Engine Technology
No new posts BMP ruckelt beim Beschleunigen Diesel Engine Technology
No new posts Gurgling sounds from the center console when accelerating Diesel Engine Technology
