Polo 6N TDI: Rattling Noise - Diagnosis & Repair
fips21
Post21-04-2003, 18:54    Subject: Polo 6N TDI: Rattling Noise - Diagnosis & Repair Quote
'In my Polo 6N TDI, manufactured in 2001, there's a rattling noise coming from the front area on the driver's side when driving over bumpy roads or, for example, a manhole cover. It's difficult to pinpoint exactly where the sound is coming from; it seems to be either in the footwell area or near the dashboard. I already took it to the workshop, and they replaced the left shock absorber. Unfortunately, that didn't fix the problem!'
It sounds like someone is lightly hitting an empty plastic cola bottle against something. It's really annoying!
Does anyone know about this problem? I would be very grateful for any advice or suggestions!
Thank you!!
Translated on 10-08-2026, 6:26.
kenny
Post21-04-2003, 19:17    Subject: Polo 6N TDI: Rattling Noise - Diagnosis & Repair Quote
I once had something similar in my Golf... I covered all the places inside where plastic rubs against plastic with felt – and the rattling went away icon_biggrin.gif.
Translated on 10-08-2026, 6:27.
brezelmann01
Post21-04-2003, 22:13    Subject: Polo 6N TDI: Rattling Noise - Diagnosis & Repair Quote
Hmm, ich kann mich nur meinem Vorredner anschließen! Filz ist die Geheimwaffe schlechthin beim 1.4er TDI! Hab bei mir auch erstmal meinen Motorraum damit verarztet. Das ist da echt schlampig gemacht! Schau dir mal die Metallleitungen der drei U-Druck-Ventile an der Spritzwand an! Die sind schon mal potentielle Kunden fürs Klappern. Desweiteren lag bei mir der Schlauch zum Wärmetauscher direkt am Bremskraftverstärker an, klapperte und scheuerte so massiv, das dieser fast durch ist. Ich werde wohl in den nächsten Tagen mal für Ersatz sorgen müssen. Und das bei einem Kilometerstand von nur 30tsd! Echt Sad!
Otherwise, I'll need to check the exhaust again. And if I remember correctly, the two cable linkages for the gear shift also come out near the driver's feet. Could something be transmitting from there into the car's interior? Otherwise, there isn't much else up front that could be rattling... I assume the engine mount (on the transmission side) is properly seated?
Good luck!
pretzelman01
Translated on 10-08-2026, 6:28.
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts Annoying rattling noise coming from the radio area / cent... Transmission, Chassis, Body & Interior
No new posts Clicking Noise Steering Belt Drive, Polo 9N3 Diesel Engine Technology
No new posts Engine Knock: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Door Knocks: Secrets & Hidden Meanings Transmission, Chassis, Body & Interior
