Fuel Injection for Hot Start
Go to page: 1, 2  Next
Michi80
Post13-08-2009, 18:05    Subject: Fuel Injection for Hot Start Quote
Hi, I drive a Golf 4 TDI with a 90 HP ALH engine. Can someone possibly tell me how to modify the injection quantity for hot starting using VAG COM? Thanks in advance. icon_lol.gif
Translated on 18-08-2026, 20:02.
Post13-08-2009, 18:27    Subject: Fuel Injection for Hot Start Quote
You mean the initial guess/starting value. Answer: Yes. I assume you want to use this to solve warm-start problems.
Michi80
Post13-08-2009, 18:30    Subject: Fuel Injection for Hot Start Quote
Sure...
Michi80
Post13-08-2009, 18:57    Subject: Fuel Injection for Hot Start Quote
Post13-08-2009, 20:18    Subject: Fuel Injection for Hot Start Quote
Sure, here's the translation:
"Please use the search function or relevant articles. I found it in 10 seconds."
Translated on 18-08-2026, 20:03.
chli1976
Karma: +185 / -0   Thank you, like it!
Post14-08-2009, 7:41    Subject: Fuel Injection for Hot Start Quote
Is there a login for EDC16 engine control units (ECUs) that allows increasing the starting fuel quantity, or do these ECUs no longer support this?
Volkswagen Golf V, manufactured in 2005, engine code BKD.
VCDS
Translated on 18-08-2026, 20:04.
Tompalatina
Karma: +2 / -1   Thank you, like it!
Post10-08-2010, 15:21    Subject: Fuel Injection for Hot Start Quote
Does anyone happen to know exactly what happens when you increase a value, for example, the initial amount? So, here's an example: If channel 5 is set to 32768 by default, and I want to increase the initial amount by 10%, what value should I try to set it to? Should it be 36045?
And what happens "behind the scenes"? Is the injection time extended while maintaining the same injection start point, or is it something else?
Post10-08-2010, 15:36    Subject: Fuel Injection for Hot Start Quote
The start of injection is essentially dependent on the coolant temperature and the amount of fuel injected. If the injection quantity (initial injection amount) is changed, the controlled start of injection also changes.
However, this is hardly relevant at the moment of starting, as no regulation can take place yet. Therefore, the static injection start setting (TDI timing checker in VCDS) must be correct.
Unfortunately, the modification mentioned does not play a role in warm start problems, as other factors are relevant here (including the starting speed and the coolant temperature seen by the engine control unit).
Translated on 18-08-2026, 20:06.
Tompalatina
Post10-08-2010, 16:16    Subject: Fuel Injection for Hot Start Quote
Thank you, Rainer, for the quick response!
Do you also know what the values look like (regarding my other question)?
Translated on 18-08-2026, 20:07.
Post10-08-2010, 16:20    Subject: Fuel Injection for Hot Start Quote
Do you also know what it looks like from a values perspective (my other question)?
No, I don't have to either. You can directly see the change in fuel injection amount when you modify the input value. icon_biggrin.gif
Tompalatina
Post10-08-2010, 16:29    Subject: Fuel Injection for Hot Start Quote
Translated on 18-08-2026, 20:08.
Tompalatina
Post10-08-2010, 22:01    Subject: Fuel Injection for Hot Start Quote
Okay, new problem. I can't change anything except the idle speed. Apparently, the login isn't working. Without logging in, I can only access channel 2 (idle speed).
Wenn ich einen Login mit 12233 versuche, reißt danach umgehend die Kommunikation ab, und ich werd' aus dem Steuergerät geworfen. Dasselbe passiert mit Logins 26281, 26282, 26252, 26232 und 22158. Ist das ein Zeichen dafür, dass der Login-Code falsch ist, oder hat das eine andere Ursache? EiDo you have any ideas?
By the way, this is the control unit for an automatic seat adjustment system.
Post10-08-2010, 22:27    Subject: Fuel Injection for Hot Start Quote
This is because the settings that apply to the ALH engine are not being sent to the ASZ control unit.
Translated on 18-08-2026, 20:09.
Tompalatina
Post10-08-2010, 22:42    Subject: Fuel Injection for Hot Start Quote
Post11-08-2010, 7:34    Subject: Fuel Injection for Hot Start Quote
"With none of them, I said it's not about the ASZ."
Tompalatina
Post11-08-2010, 7:50    Subject: Fuel Injection for Hot Start Quote
Ah, okay, so I misunderstood that.
Translated on 18-08-2026, 20:10.
No new posts Einspritzmenge Diesel Engine Technology
No new posts Einspritzmenge 1Z tdi 08-'94 Diesel Engine Technology
No new posts RWG und Einspritzmenge bei AFN On-Board Diagnostics (OBD)
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
