Latest engine control unit (ECU) software for Audi A4 170 hp
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post25-02-2013, 13:12    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Hey guys,
Since Audi and VW are currently running a service campaign for the PPD elements, I wanted to ask if a new software version will also be installed for the engine control unit. As far as I know, the current version for the A4 170 PD PPD with engine code BRD is 9973. Is there perhaps a newer version available?
Thank you very much for your replies.
Audi SQ5 8R Cvub
Back to top Profile PM Email
Post25-02-2013, 14:29    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Hi.
Perhaps this is a hint:
I (BMR in the Passat) have four new injectors, but I didn't get a new software update.
Address 01: Engine; Label file: User\03G-906-018-BMN.lbl
Part number: SW: 03G 906 018 EM, HW: 03G 906 018 EM.
Part: R4 2.0l PPD1.2 G 4369
Revision: --H42---
Serial number: VWZCZ000000000
Coding: 0000072
Operating number: WSC 45489 142 83388
mullemaus
Post25-02-2013, 14:36    Subject: Subject: Latest engine control unit software for Audi A4 170 Quote
Hi guys,
A few more details about the control unit (such as the part number) would be helpful. The easiest way is to do a scan using VCDS. icon_cool.gif icon_wink.gif
Post25-02-2013, 16:24    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Where the question and the reason for it have nothing to do with each other.
The Duesen-TPI doesn't explicitly mention "UPDATE" – at most, it can be implicitly inferred if an update is part of another action.
pa-mm6
Post25-02-2013, 21:20    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Here's the VCDS log.
Vehicle type: 8E - Audi A4 B6/B7.
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Vehicle Identification Number: xxxxxx
Mileage: xxxxx
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine. Label file: RKS\03G-906-018-BRD.lbl.
Part number SW: 03G 906 018 AQ, HW: 03G 906 018 AQ.
Part: R4 2.0l PPD1.3 G 9973
Revision: --H43---
Serial number:
Coding: 0000072
Operating Number: WSC xxxxxxx
VCID: xxxxxxx
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
I'm just wondering if Audi might have released an update related to the PPD (potentially problematic device) issue. I understand that 9973 was the latest version until recently, or even currently, but anything is possible...
Has anyone received the new software yet? If not, can anyone tell me what changes Update 9973 brought? My friend didn't really open up about it during that Update.
Sure, here's the translation:
"Thank you in advance."
Best regards.
tom
Audi SQ5 8R Cvub
Post25-02-2013, 21:56    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Do you have VCDS?
Then, please enter your license information in your user profile. It simplifies the support process. icon_wink.gif
pa-mm6
Post25-02-2013, 22:21    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Autoservice wrote:
Do you have VCDS?
Then, please enter your license information in your user profile. This simplifies the support process. icon_wink.gif
Sure, I bought VCDS directly from Rainer. How can I register the license?
Best regards.
Tom.
Audi SQ5 8R Cvub
Post25-02-2013, 22:29    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Enter the information under "Settings," then "Serial Number."
You can find the license number in VCDS: VCDS/About.
pa-mm6
Post25-02-2013, 22:35    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Hi, it's registered. What benefit does this give me now?
Best regards.
tom
Audi SQ5 8R Cvub
Post25-02-2013, 22:48    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
The license will be reviewed manually, which unfortunately may take some time.
If you are a customer of the online store, you only need to use the same email address in the forum as you do in the store.
What it offers: expanded, or general, support regarding VCDS icon_wink.gif.
pa-mm6
Post26-02-2013, 11:48    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
Hi, can anyone tell me which software version is the most current one for the BRD?
Perhaps Audi released an update in the past few months.
Best regards.
tom
Audi SQ5 8R Cvub
vagtuning
Post18-03-2013, 12:42    Subject: Latest engine control unit (ECU) software for Audi A4 170 hp Quote
There are no newer versions available for the 018 AQ mentioned above.
This is the most recent one, and it appears to be the last one for the foreseeable future.
At least, nothing in that direction is planned.
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU Software Update for ARL Engine? On-Board Diagnostics (OBD)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts Audi A3 8P 1.9 TDI BLS: Parts & Info Diesel Engine Technology
