24-03-2013, 22:03 Subject: Exhaust pipe for auxiliary heater |
Hi.
I currently have a 2010 Touran with a crack in the exhaust pipe of the auxiliary heater.
While the individual parts are labeled in the picture, they are not sold separately; they are only available as a complete exhaust system.
Does anyone know of alternative sources for 5 cm corrugated pipe?
| Description: |
| File size: |
112.29 KB |
| Viewed: |
13082 times |
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂźnchen & Passau
24-03-2013, 23:07 Subject: Exhaust pipe for auxiliary heater |
Hi Martin!
You can find them at any Webasto/Eberspächer/StHzg. dealer.
If necessary, I also have some extra lying around, and I'd be happy to send you some.
Best regards from Munich!
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
24-03-2013, 23:17 Subject: Exhaust pipe for auxiliary heater |
...or with a reputable Bosch service center that offers adequate support.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
mdonau Blaumann
Joined: 01/01/2005 Posts: 248 Karma: +5 / -0 Location: 24939 1988 Audi 80 Premium Support
25-03-2013, 13:57 Subject: Exhaust pipe for auxiliary heater |
..and pay attention:
Webasto 22mm, Eberspächer 24mm.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Profile PM Garage |
27-03-2013, 18:55 Subject: Exhaust pipe for auxiliary heater |
Here comes the big one.
In the Golf (same heater as in the turkey), you can buy this part separately.
1K0 819 178 C
Okay, I'll get back to you later - I need to go take my measurements.
Profile PM Garage |
27-03-2013, 19:36 Subject: Exhaust pipe for auxiliary heater |
SHIT
Horn off.
Remove the bells.
and now it's not going any further - the pipe is really stuck on the two flanges.
And if I just wrap GUMGUM around it?
| Description: |
| File size: |
246.13 KB |
| Viewed: |
9536 times |
| Description: |
| File size: |
295.79 KB |
| Viewed: |
7612 times |
Profile PM Garage |
27-03-2013, 20:37 Subject: Exhaust pipe for auxiliary heater |
Quote: | | And if I just wrap GUMGUM around it? |
 Where are we?
Spray with rust remover. If that doesn't work, cut the pipe and carefully break off the rest using pliers or a pipe cutter.
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
29-03-2013, 11:05 Subject: Exhaust pipe for auxiliary heater |
Definitely replace it, don't repair it.
I also have one. It's 24mm. If you're interested, let me know.
| Description: |
| File size: |
32.74 KB |
| Viewed: |
6934 times |
Passat Variant BGW 2005
30-03-2013, 16:47 Subject: Exhaust pipe for auxiliary heater |
The old hose crumbled in the middle.
I have wound down the ends.
With enough courage, everything went perfectly smoothly.
I had to scrub the bottom of the SH very thoroughly.
Unfortunately, I made the new arch slightly too wide (the old one was 20cm when measured, the new one was shortened to 21cm), so the horn had to be repositioned  .
When does the old auxiliary heater actually turn on?
I would like to test the fun.
| Description: |
| File size: |
70.94 KB |
| Viewed: |
21839 times |
Profile PM Garage |
31-03-2013, 8:11 Subject: Exhaust pipe for auxiliary heater |
Eberspächer and Webasto both offer heat-resistant rubber sleeves that can be slipped over the exhaust pipe to keep it a safe distance from other parts, especially in tight spaces. Heat-resistant tape commonly used in motorsports is also excellent for insulating the exhaust pipes of auxiliary heaters. As a result, the exhaust pipe will be at best hand-warm, and the risk of fire is eliminated.
| Description: |
| File size: |
29.22 KB |
| Viewed: |
7232 times |
31-03-2013, 10:29 Subject: Exhaust pipe for auxiliary heater |
NE,
There's nothing wrong with the pipe.
I only measured it a bit too long, and I only realized after the complete assembly that the horn still needs to go in front.
Okay, I've adjusted the horn mounting bracket, all done.
If you compare my first and last picture, you can guess what I did by looking at the steps of the stand.
Removing the pipe bend again seemed like too much work, and I felt that it rusted through so quickly (MJ10) mainly because of its tight bend.
Profile PM Garage |
31-03-2013, 10:48 Subject: Exhaust pipe for auxiliary heater |
It's okay. I just meant it in a general sense, in case someone ever needs to install exhaust pipes like that. In the engine compartments of modern vehicles, which are often enclosed with plastic, the fire hazard posed by auxiliary heaters is a factor that should not be underestimated.
michiglaser Blaumann
Joined: 05/03/2007 Posts: 274 Karma: +6 / -0 Location: Lkr. KEH 2007 Audi A4 Avant Premium Support
08-05-2013, 14:37 Subject: Exhaust pipe for auxiliary heater |
In the SHK (sanitary, heating, and air conditioning) industry, there are flexible stainless steel corrugated tubes available for solar installations.
They might not be quite as flexible, but you can often find leftover materials at your local heating and plumbing supplier.
At least one part fit the Eberspächer auxiliary heater from the T4.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Profile PM Garage |
