Octavia 2.0L TDI BKD Problems - Solved
Go to page: 1, 2, 3, 4  Next
gtikasper
Post29-03-2013, 1:35    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Hello everyone.
First of all, a big thank you to this forum!
Unfortunately, despite months of searching, I still haven't found a solution to my engine problem.
Vehicle specifications:
Octavia 1Z.
2.0L TDI
103 kW / 140 hp
with DSG.
Year of manufacture: 2005.
MKB: BKD
190,000 km
Now, let's address the problem:
Severe shaking/jerking ONLY when the engine is warm.
"The engine has been experiencing severe jolting between 1300 and 1900 RPM for the past week. This issue has been present for the last 30,000 kilometers. The jolting is so strong that the entire car shakes. Once it gets out of that RPM range, the engine runs smoothly again."
We replaced the mass airflow sensor (MAF), the pressure sensor cable harness under the valve cover, all the charge air and vacuum hoses are leak-free, and we replaced the diesel filter.
Last Friday, we removed and cleaned the AGR/throttle valve (it was completely covered in deposits). It ran normally for a day (about 50 km driven). On Saturday, it then displayed an "exhaust" error, and when warm, it started to sputter heavily above 1900 RPM, up to about 2600 RPM.
-It's running at full power and reaching its top speed of 215 km/h.
- No oil consumption.
- Slight water loss, requiring a small amount every 2000 km.
- The turbo is barely audible.
- No cold start issues.
- No white smoke or soot.
-Problem only occurs above 60/70 degrees.
I just bought a VCDS and I'm hoping to be able to locate the error somehow.
Does anyone have any ideas on where I should start now?
I have relatively little experience with material handling and logistics transportation.
Translated on 10-08-2026, 22:01.
Post29-03-2013, 12:01    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Does anyone have any ideas about where I should start now?
First, perform a complete error scan and post the results here.
And identify the source of water loss.
See, for example, here:
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 10-08-2026, 22:05.
gtikasper
Post29-03-2013, 16:18    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Addendum;
The water loss is extremely minimal; I just checked again. After 2000 km, there's very little to no consumption.
The AGR (presumably a waterway or canal) has been completely closed off with a plate for the past few days.
The diesel consumption is 4.6 liters per 100 kilometers during normal driving on country roads. If you drive carefully, it's possible to achieve a consumption of 4.2 liters per 100 kilometers.
I will run the error scan later.
Translated on 10-08-2026, 22:07.
Karma: +1353 / -0   Thank you, like it!
Post29-03-2013, 17:14    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
The "exhaust emissions" error is likely due to the EGR valve, which was probably sealed icon_exclaim.gif for testing purposes only. The EDC system might detect this. However, you'll definitely see more information with VCDS.
That has nothing to do with the shaking/vibration.
"First, run a complete error scan and post the results here."
Translated on 10-08-2026, 22:08.
gtikasper
Post29-03-2013, 18:28    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
A master once said that you should try closing the AGR for testing purposes.
What measurement blocks should I record during the "bouncing" process?
I'll post the error scan as soon as I get home...
Thank you very much in advance.
Best regards, Melli.
Translated on 10-08-2026, 22:09.
gtikasper
Post29-03-2013, 19:49    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Here's the error scan.
Log-OD OC 140-TMBGE61Z462179026-190200km.txt
 File name:  Log-OD OC 140-TMBGE61Z462179026-190200km.txt
 File size:  11.77 KB
 Downloaded:  1156 times
Translated on 10-08-2026, 22:10.
Post29-03-2013, 21:55    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Exactly one master said that you should try closing the AGR for testing purposes at some point.
Unfortunately, this is not a good approach for this motor because it would immediately result in an error message and activate the emergency program.
Your error message in the scan may therefore originate directly from this measure. However, since the throttle body module and EGR valve are potential sources of errors, it would be useful to remove both and examine them. If they are defective, you can usually tell fairly quickly.
See:
/viewtopic.php?t=22804&highlight=bre+agr
Translated on 10-08-2026, 22:11.
gtikasper
Post31-03-2013, 13:56    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Can anyone tell me which MWB (Material Work Breakdown) I should be logging?
I hope we can see something that triggers the stuttering/jerking.
It definitely has something to do with the temperature.
Translated on 10-08-2026, 22:12.
DieselBär30x
Avatar-DieselBär30x
Post31-03-2013, 14:17    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
In case of problems within certain temperature ranges, always and first check the plausibility of all temperature sensor readings, for example, when a vehicle has been completely cooled down overnight.
So, using VCDS, check the measuring blocks in the engine control unit and see if all the displayed temperatures are approximately the same.
As Rainer already mentioned: If the wiring harness is definitely not the problem, then the AGR (Anti-Pollution Gear Regulation) and throttle body module are the next likely candidates to investigate.
Best regards from Munich!
Translated on 10-08-2026, 22:13.
gtikasper
Post31-03-2013, 14:41    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Thanks for the tip. Do I just need to check it with the ignition on, or do I also need to start the engine?
Should I also measure the temperatures when the system is in a warm state?
"Best regards," or "Sincerely," (depending on the context)
Translated on 10-08-2026, 22:15.
DieselBär30x
Avatar-DieselBär30x
Post31-03-2013, 14:47    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Sure.
Only with the ignition on, because when the engine is running, various temperatures immediately start to rise and at different rates from the outside temperature - makes sense, right? icon_wink.gif
In warmem Zustand die Werte auf Plausibilität zu prßfen wird an der Erfahrung scheitern, darum hast Du mit den "kalt"-Werten erstmal einen guten Ansatz, ob's da fehlt oder eher wo anders (s. R(Ainer's post).
Translated on 10-08-2026, 22:16.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post31-03-2013, 15:01    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
"Hey, let's check the pressure holding capability of the tandem pump. If it's not maintaining pressure, the seals on the internal gear elements are likely defective. I had a similar issue some time ago; I disassembled it, replaced the seals, and it's been running perfectly ever since."
Best regards.
tom
Audi SQ5 8R Cvub
Back to top Profile PM Email
gtikasper
Post31-03-2013, 21:03    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
Here are the temperatures in a cold state.
Coolant temperature: 15.3°C.
Oil: 26.1°C
Fuel: 13.5°C
Intake manifold: 6.3°C
Clutch: 17.1°C
Then I looked at the MWB 013 while it was in a warm state. Are those values/deviations normal? icon_eek.gif
Thank you for your help.
The Octi must be running perfectly in 4 weeks, because a vacation to the WĂśrtersee is planned (1200 km). icon_rolleyes.gif
 File size:  44.98 KB
 Viewed:  20939 times
Translated on 10-08-2026, 22:18.
Post31-03-2013, 21:07    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
"Normal... but that's how he normally drives, right?"
So, why shouldn't the values be normal during the time when the car is driving normally? icon_rolleyes.gif
What does the person asking the question learn from this?
Translated on 10-08-2026, 22:19.
gtikasper
Post31-03-2013, 21:29    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
icon_sad.gif I have absolutely no idea about that. The technology is unfortunately too new or not as simple as it was with a Golf 2.
Then I won't see anything during a logging operation, even under full load, because it only happens at partial load, right?
This car is driving me crazy icon_lol.gif.
Translated on 10-08-2026, 22:20.
Post31-03-2013, 21:30    Subject: Octavia 2.0L TDI BKD Problems - Solved Quote
dieselschrauber wrote:
What does the person asking the question learn from it?
Um... the log should primarily contain information about the stuttering, right?
Translated on 10-08-2026, 22:21.
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Solved - Problems with Automatic Transmission Touareg 5R On-Board Diagnostics (OBD)
No new posts Octavia 1Z VCDS Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Engine Diagnostics: 1.6D/TD Solutions Diesel Engine Technology
