Audi A3 Rear License Plate Screws 8PA
Post21-07-2014, 19:30    Subject: Audi A3 Rear License Plate Screws 8PA Quote
Hi.
After 8 years, a registration plate had to be removed from an 8P vehicle.
The heads of the screws broke off immediately with icon_sad.gif.
Now, the situation is as follows.
According to Audi, those are M6x12 screws... or at least, they used to be.
What remains?
Is it just a matter of drilling and re-cutting?
 File size:  386.87 KB
 Viewed:  2805 times
Translated on 29-07-2026, 10:09.
Post21-07-2014, 20:23    Subject: Audi A3 Rear License Plate Screws 8PA Quote
New mother moving in, all good.
Translated on 29-07-2026, 10:10.
Karma: +1355 / -0   Thank you, like it!
Post21-07-2014, 20:24    Subject: Audi A3 Rear License Plate Screws 8PA Quote
Hi there,
Are those PA speakers mounted in the tailgate?
Sure, here's the translation:
"Best regards."
Post21-07-2014, 22:28    Subject: Audi A3 Rear License Plate Screws 8PA Quote
New mother moving in and all is well.
If this still goes well icon_wink.gif, the metal seems to be getting a bit brittle icon_wink.gif.
Alternatively, you can use a metal screw on either the left or right side if you want to minimize the effort involved.
Translated on 29-07-2026, 10:11.
Post22-07-2014, 7:31    Subject: Audi A3 Rear License Plate Screws 8PA Quote
Autoservice wrote:
Hopefully, it will still work out okay.icon_wink.gif The metal seems a bit brittle icon_wink.gif.
I thought the same thing at first glance, but look again closely; the flap is fine, it's just the nut that's corroded. icon_wink.gif
Translated on 29-07-2026, 10:12.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post22-07-2014, 8:19    Subject: Audi A3 Rear License Plate Screws 8PA Quote
Hey,
I doubt you'll be able to drill anything there anymore.
These stupid screws sometimes spin without tightening before the threads strip.
I think I once saw someone recreate it and then replace it.
Personally, I only use special double-sided gel adhesive tape anymore.
That also eliminates those awful holes in the plate or bracket.
Translated on 29-07-2026, 10:13.
Post22-07-2014, 9:23    Subject: Audi A3 Rear License Plate Screws 8PA Quote
I thought the same thing at first glance, but look again carefully; that's not the flap, it's just the bracket that's rusting.
"That's icon_wink.gif. Then it's quite simple: carefully grind off or cut away the female nut, install a new nut, and you're done. Of course, remove the old nut from inside the valve body beforehand."
The nuts can be pressed in even without special tools, using a screw, washer, and nut.
Translated on 29-07-2026, 10:14.
Post22-07-2014, 9:28    Subject: Audi A3 Rear License Plate Screws 8PA Quote
UI
How does this "installation" work? Do you have a picture of a loose, new strut?
Are we just really tightly inserted/pulled in from the inside?
http://parts.audiofalexandria.com/product_images/e/564/72D7DDB2EC1A4856C69EA9D0D7747B4C__17865_zoom.jpg
Translated on 29-07-2026, 10:15.
Post22-07-2014, 11:45    Subject: Audi A3 Rear License Plate Screws 8PA Quote
how does this "withdrawal" ...
Essentially, it works like pop rivets. The thread is pulled outwards, which creates a compression at the point where the clamping should occur.
Without tools, you take a sturdy nut and a washer. First, screw the nut onto the bolt, then place the washer on top of it. Screw both the nut and the washer into each other, hold the bolt in place, and rotate the nut towards the rivet nut until it is tight... but no further.
The material used should be able to withstand the stress. Therefore, do not use toys.
Translated on 29-07-2026, 10:17.
LZ
Post28-07-2014, 18:37    Subject: Audi A3 Rear License Plate Screws 8PA Quote
Bike repair shops have these tools along with the necessary attachments – and sometimes, the mounting points for water bottle cages can also break off!
Translated on 29-07-2026, 10:18.
No new posts Audi 8P documentary: The rear bumper/spoiler has a wavy s... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action Polo MJ 2000, rear brake hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P: Rear View Camera Issues Transmission, Chassis, Body & Interior
No new posts Audi A2 conversion to disc brakes at the rear Transmission, Chassis, Body & Interior
No new posts Audi A4 B7 Wiper Problems: Front & Rear Fix Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A4 Airbag: Rear Crash Sensor Ohms Value On-Board Diagnostics (OBD)
