Profile PM Garage |
16-01-2013, 10:18 Subject: PPD Repair: Get Your Printer Fixed Now! |
Too bad.
I was unable to find any details about action 23H9.
Besides those I already knew about, because the campaign has been active in England for a year.
PPDEs with index D and M should be replaced.
m; Transparency, Teamwork
Translated on 30-09-2026, 5:17.
Profile PM Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
16-01-2013, 23:45 Subject: PPD Repair: Get Your Printer Fixed Now! |
Car is running again!
Service measure 23H9, process number 2027647/7, release date 07.01.2013.
Basically, the check verifies whether ALL product part documents (PPDs) have a specific part number status.
All part numbers with "D" or "M" will be replaced free of charge in SX models (up to 103 kW).
or, specifically, in part number TX (starting from 120-125 kW). Wiring harness included! 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Translated on 30-09-2026, 5:18.
Profile PM Garage |
27-01-2013, 16:12 Subject: PPD Repair: Get Your Printer Fixed Now! |
I received a letter from the car dealership, not from the KBA (Federal Motor Transport Authority).
"... schedule an appointment ... a free product optimization for you ..."
Profile PM Garage |
07-02-2013, 22:01 Subject: PPD Repair: Get Your Printer Fixed Now! |
UI,
Sure.
Now the buck is starting to rut again.
I wouldn't have expected the difference in overall performance and lambda readings to be so significant.
So far, I've only ridden it in the city. But the long delay after the initial acceleration, or when "accelerating from a rolling stop," is gone. It pulls, not quite like a BLS, but more smoothly and responsively.
Let's see what the highway has to say  .
Translated on 30-09-2026, 5:19.
Profile PM Garage |
bafische Profi-Schrauber
13-03-2013, 23:01 Subject: 23h9 Erfahrungen: Reviews & Testbericht |
Yesterday, my 2008 Passat, with a BMA engine and 165,000 km on the odometer, broke down.
Fehler im Stromkreis der PPD Elemente. Nothing was working.
After calling the service center, he told me about a free, quality-enhancing measure called 23H9.
Although I previously received information from the VW recall website stating that my vehicle was not affected by the recall, I was not contacted by my dealer.
I just picked up my Passat and had 4 new power plant devices (PPDs) along with their wiring harnesses replaced.
I strongly recommend that everyone replace the glow plugs and the valve cover gasket at the same time during this service. I examined the old glow plugs and tested them on our dynamometer at the company. Three of the plugs showed a significantly delayed heating time, and two of the plugs had a temperature approximately 300K lower than a reference plug.
While the pens are monitored via diagnostics, this monitoring only detects complete failures.
After 165,000 km on the highway, they were worn out.
However, it remains to be seen whether this will improve the starting behavior.
I'm looking forward to improved cold noise performance, a reduced tendency for dropouts, and a noticeably more harmonious torque delivery.
I would highly recommend that every PPD driver call their local dealer and inquire about their VIN.
Greetings. "Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 30-09-2026, 5:22.
14-03-2013, 9:16 Subject: PPD Repair: Get Your Printer Fixed Now! |
Hi.
There are several "promotions" or "offers" available.
Yes, yours probably doesn't fall under the 23H9 category.
However, the practice of replacing one nozzle and then, later, replacing all four nozzles when one fails has been "active" for some time, and it will likely also apply to the BMA.
I should have known about the GSK thing a little earlier  .
I'm looking forward to reading your progress reports.
Greetings.
Translated on 30-09-2026, 5:24.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
18-07-2013, 17:26 Subject: PPD Repair: Get Your Printer Fixed Now! |
Is there a document or information available related to "Action PPD"?
Here's a vehicle that we already checked at the address above in April – the vehicle was affected --> it has PPD injectors with "M" at the end. I've already replaced one injector on this vehicle.
Unfortunately, due to private reasons, the exchange can only take place now --> Problem, according to the  , the vehicle is not affected, and according to the query, it is also not  . LG, Onkel BM
Translated on 30-09-2026, 5:25.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
19-07-2013, 9:09 Subject: PPD Repair: Get Your Printer Fixed Now! |
The action was discontinued at VW due to poor availability of spare parts.
Translated on 30-09-2026, 5:26.
comco
Joined: 11/14/2011 Posts: 29 Karma: +1 / -3 Location: Berlin
Registered VCDS User
24-07-2013, 20:06 Subject: PPD Repair: Get Your Printer Fixed Now! |
Autoservice wrote: | ... the exchange can only take place now --> problem, according to the , the vehicle is not affected, and according to the query, it is also not  | .
I can only suggest contacting Volkswagen at 0800 VOLKSWAGEN to submit a request for goodwill consideration.
Please translate the following text from German to English. Provide ONLY the translation, no explanations. Please refer to the recall campaign and state that the affected vehicle was not listed in the recall database during the recall period (e.g., end of January 2013), even though it is equipped with the defective PD components.
Please refer to the letter dated August 9th (which replaces the information from July 5th, 2011) regarding:
Separate processing of pump-injector elements (2.0 liter TDI, engine codes: BKP, BMN, BMR, BMA, BUZ, BVE, BWV).
This document indicates that Volkswagen will cover 100% of the costs for repairs related to electrical faults in PPDS (presumably referring to a specific component or system) even after the warranty period, up to a maximum of 7 years.
However, the application for financial assistance can take up to 6 weeks, but it's still better than having to finance the PD components yourself.
Good luck. Bye
Jürgen
_________________________________________
Für den Spass/Winterauto: Audi TT Q und die Arbeitstier: Octavia 2 RS,
Für noch mehr Spass: R1200S, Laverda Formula, SV 1000 und NSU MAX
Translated on 30-09-2026, 5:28.
24-07-2013, 20:24 Subject: PPD Repair: Get Your Printer Fixed Now! |
Thank you for your information.  As I said, it is not my vehicle.
If anything develops, a report will be issued. LG, Onkel BM
Translated on 30-09-2026, 5:30.
comco
25-07-2013, 9:29 Subject: PPD Repair: Get Your Printer Fixed Now! |
Update: Skoda has also discontinued the recall campaign for PD elements. Bye
Jürgen
