VCDS 11.11.5 is outdated, VCDS: Software is outdated
Post02-09-2013, 8:07    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
Unfortunately, the new VCDS release was not completed in time. The messages stating that VCDS 11.11.5 is outdated can be ignored, as the functionality of the program is not affected by this.
New orders will be delivered with software version 11.11.6. Updates to the upcoming release will be provided as usual, free of charge, or via the automatic update mechanism of VCDS.
Best regards, Rainer
Post05-09-2013, 15:40    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
Dear Customers, Individuals who might be interested,
Please choose between the first or second option in the red text.
It's not helpful to make phone calls and, even worse, to show up uninvited at my doorstep when I've just arrived minutes before and haven't even had time to use the restroom.
Thank you!
 Tja, was nun? Flenn, flenn, flenn... große Katastrophe für einige.
Zielführend: Meldung wegklicken und mal nachschauen, ob es ein Update gibt. Wenn nicht: Nicht herumflennen und abnerven, sondern bitte etwas Geduld. Danke.
 File size:  49.18 KB
 Viewed:  14732 times
Post05-09-2013, 21:01    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
Version 11.11.6 (German) including KPower, KDataScope, KFuel, KPerformance for download:
http://shop.dieselschrauber.de/support-downloads.php
Post06-09-2013, 5:27    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
Improvement suggestions:
1. Adding an "Don't show this again" option in the speech bubble, so that only one click per release is needed to disable it.
or
2. Automatic hiding of information after ~ 3 seconds and release of normal menu functions without requiring the user to click.
or
3. Display the information with forced clicks only for ~ 5 starts from VCDS - after that, most users should understand what it's about. Optionally, starting from the 6th. Automatic switching to Solution 2 with the outdated VCDS version.
Post06-09-2013, 12:31    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
or...
From my point of view, the entire function is unnecessary. One can clearly see the effect.
A note in the initial window "please regularly or occasionally check the shop for updates" is perfectly sufficient.
Conversely - if someone is unable to click a simple message, they haven't understood anything and are unfortunately completely overwhelmed by the subject matter.
Blackfrosch
Post18-10-2013, 9:13    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
That probably has a reason:
Because there are unfortunately also "copies" of VCDS that only "function" up to a certain version. Then it is also good that this message comes in the way it does.
It was shocking to see what was being sold on the used market as a "legitimate" VCDS.
It should probably be feasible to check the software every 3 months for a new version, given its quality. Otherwise, we follow what Auto Service says.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post22-11-2013, 10:42    Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated Quote
Where is the problem?
I saw this once and clicked away.
I checked for updates the second time, but there was nothing new. Okay.
the 3rd Clicked away.
Now the solution has been received.
I wouldn't have even asked about this if it hadn't completely stopped working.
Klaus
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM/VCDS Software: Which Version? On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS: Version 11.11.2 Update & Features On-Board Diagnostics (OBD)
