Tire Size: 195/60 vs. 195/65
Toledo-Andy
Post29-04-2003, 8:57    Subject: Tire Size: 195/60 vs. 195/65 Quote
Are there any major issues if I install 195/60 tires instead of 195/65 tires on standard steel rims, other than needing to go to the TÜV (technical inspection)?
Translated on 25-10-2026, 15:06.
PrivatBereich
Post29-04-2003, 9:19    Subject: Tire Size: 195/60 vs. 195/65 Quote
Well,
der Gesamt-Raddurchmesser ist somit kleiner. That is to say.
To achieve the same real speed, the engine needs to run at a higher RPM, icon_arrow.gif which results in increased fuel consumption.
- Consequently, the speedometer also displays an inaccurate reading.
- In the event of an accident, you will face immense problems. The police usually check the tires, and the insurance company checks them 100% of the time. If it turns out that you had the wrong tires on... icon_arrow.gif ...may God have mercy on you... You will definitely receive partial blame and points (similar to having worn-out tires).
icon_arrow.gif So, stay away from those, tires can't possibly be that cheap, it's not worth it!
Translated on 25-10-2026, 15:08.
No new posts TDI Engine Swap: Replacing 1.8 ADZ Engine Diesel Engine Technology
No new posts Cold Cleaner vs. Diesel: A Sustainable Alternative? Diesel Engine Technology
No new posts General utility of PD oil instead of 505.00? Diesel Engine Technology
No new posts Sport Air Filters vs. Turbo: Which is Best? Diesel Engine Technology
