Audi Q5 Diesel Recall 2008: Service Issues
chriskross
Post29-04-2014, 19:26    Subject: Audi Q5 Diesel Recall 2008: Service Issues Quote
Hello!
Today, I had a problem resetting the service interval on a 2009 Audi Q5 with a 3.0 TDI engine.
Although all the fault codes were reset, the service light continued to illuminate on the instrument cluster.
Could only reset the SIA using the KTS; has anyone else experienced this problem?
A6 AFB
A6 BRE DPF
Translated on 20-08-2026, 20:57.
Karma: +807 / -0   Thank you, like it!
Post29-04-2014, 21:09    Subject: Audi Q5 Diesel Recall 2008: Service Issues Quote
sollte eigentlich gehen. See also:
The "trick" is to carefully read the menu options and select the correct ones!
Sometimes it's easy to forget something; recently, with my Audi A6 4F, I had to select three different entries before the longlife service interval was correctly reset.
If anything is missing, you can see it in the table where the values for the adjustment channels are displayed. Please check if all of those values seem reasonable.
Translated on 20-08-2026, 20:58.
No new posts Upgrade of MMI Basic Sound System Audi A6 4F up to KW35/2008 Troubleshooting & Guides
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Opel Astra 2008: Specs, Review & Price On-Board Diagnostics (OBD)
No new posts Audi A4 8K, year 2008, engine code CAGA - Engine breather... Diesel Engine Technology
No new posts Retrofitting hands-free system for Audi A4 8K, year 2008 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A4 2008 8K Underbody protection / Stone chip protection Transmission, Chassis, Body & Interior
