1.4 TSI Error Fuel Pressure Regulator Valve
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Lochhaas123
Post17-05-2014, 11:01    Subject: 1.4 TSI Error Fuel Pressure Regulator Valve Quote
Good day,
I am experiencing the following problem with my Golf 5 1.4 TSI engine: During an overtaking maneuver, the engine suddenly lost power. Now I have read out the fault memory and the following error was recorded: Mechanical failure of the fuel pressure regulating valve.
How should I proceed best?
Karma: +791 / -0   Thank you, like it!
Post22-05-2014, 18:58    Subject: 1.4 TSI Error Fuel Pressure Regulator Valve Quote
My suggestion would be to check and, if necessary, replace the fuel regulator valve.
Lochhaas123
Post22-05-2014, 21:34    Subject: 1.4 TSI Error Fuel Pressure Regulator Valve Quote
How do I check if it's happening sporadically?
Post23-05-2014, 10:09    Subject: 1.4 TSI Error Fuel Pressure Regulator Valve Quote
In cases where sporadic errors occur rarely, there are 3 possibilities:
- One continues driving until the corresponding part is completely broken.
- We are looking for specific hours, and either luck or bad luck determines whether the malfunction occurs and can be reproduced.
- You replace the part if the engine control unit (ECU) indicates that it is faulty. But one thinks about it first and considers whether it could really be the case, or whether it is simply a side effect / consequence of something else.
If you have VCDS, why don't you use it accordingly?
1. "Post Autoscan data to identify the vehicle and its components."
2. If the "Fuel Pressure Regulator Mechanical Fault" error occurs, why don't you simply log the target and actual fuel pressure values, drive the car for a while to allow the error to occur, and then check the measured values?
No new posts P2293 - Fuel Pressure Regulator Valve (N276), Mechanical.... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Where is the error? Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts Fehler in der WFS Diesel Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
