Starter Motor Touran BRU
Post04-07-2014, 20:53    Subject: Starter Motor Touran BRU Quote
Hi.
It's about a Touran manufactured in 2006 with the 90 hp TDI "BRU" engine.
When the engine is properly warm, the starter motor stops working.
It's smoking and smelling like electricity.
Everything is okay when it's cold.
My analysis idea was:
- If it doesn't start and doesn't click when you try to start it, it will be the magnetic switch.
- If it clicks, but doesn't turn, it's more likely the starter motor itself}.
Am I right about that?
Greetings.
Translated on 11-09-2026, 3:08.
Post05-07-2014, 7:39    Subject: Starter Motor Touran BRU Quote
- If it doesn't start and you don't hear a click when you try to start it, it will likely be the magnetic switch.
- If it clicks but doesn't turn over, it's more likely the starter motor itself.
Yes, if the starter motor receives enough power.
Translated on 11-09-2026, 3:10.
Post06-07-2014, 21:22    Subject: Starter Motor Touran BRU Quote
Okay, please provide the text you would like me to translate from German to English.
The box can be surprisingly easily pushed across a meadow by two people icon_wink.gif.
It clicks when it's having another "phase" and doesn't want to turn.
It seems like a significant amount of power is flowing.
I now believe that it's not the temperature, but a specific resting position that's causing the problem. If he stays "there," it won't work the next time.
The thing is coming out, and then hopefully everything will be alright.
Hmm... that reminds me of that clearly defective dual-mass flywheel.
It wasn't as if that would have affected the starter motor, so how could it possibly have done so?
Translated on 11-09-2026, 3:11.
Post07-07-2014, 5:57    Subject: Starter Motor Touran BRU Quote
Once you've removed the starter motor, you can inspect its pinion gear. If, for some reason, any loose parts have ever gotten between the gears, you should be able to see it. Otherwise, I can't imagine that the dual-mass flywheel (ZMS) has anything to do with it.
Translated on 11-09-2026, 3:12.
Post07-07-2014, 19:33    Subject: Starter Motor Touran BRU Quote
Apparently, Bosch and Valeo components were used together, as the parts catalog in the BRU system lists both brands with different part numbers.
Can you swap them out, meaning can you remove the BOSCH part and replace it with a Valeo part (if you can get one at a good price)?
Translated on 11-09-2026, 3:13.
Post07-07-2014, 19:56    Subject: Starter Motor Touran BRU Quote
Is it possible/allowed to swap them out, i.e., remove the BOSCH and install a Valeo (if you can get one at a good price)???
That should fit. I also replaced a Valeo starter with a Bosch starter (Passat 3C from 2007) a few weeks ago.
Translated on 11-09-2026, 3:14.
Post08-07-2014, 10:39    Subject: Starter Motor Touran BRU Quote
I'm not sure how the starter shaft is mounted on the clutch side, but I want to mention that in a very old 1.6D engine (swirl chamber), the starter shaft was housed in a bearing bush located in the clutch bell.
The bearing bush was worn out/broken, which caused the starter motor to occasionally not engage its pinion gear with the flywheel ring gear, but instead to push it *onto* the ring gear. In the latter case, the starter motor would either partially block or damage the ring gear.
-> Check the starter shaft and ring gear for damaged teeth, paying particular attention to the area where they engage with the flywheel.
Translated on 11-09-2026, 3:15.
Post08-07-2014, 11:20    Subject: Starter Motor Touran BRU Quote
The starter motor should be self-supporting, meaning it should not be guided or supported by the transmission.
I suspect there's a defect in one of the windings or on the commutator. If it gets stuck in that specific position, it will simply stop working.
Translated on 11-09-2026, 3:16.
Post08-07-2014, 12:52    Subject: Starter Motor Touran BRU Quote
Autoservice wrote:
I guess there's a defect in one of the windings or on the commutator. If it gets stuck exactly there, then nothing will work anymore.
Based on the most recent cancellations, that was my assumption as well.
Translated on 11-09-2026, 3:17.
Post10-07-2014, 17:35    Subject: Starter Motor Touran BRU Quote
Meanwhile, the starter motor stopped working altogether.
Just a "click" from the magnetic switch.
The shaft has approximately 2mm of play laterally.
It probably isn't worth trying to fix it, is it?
 File size:  286.7 KB
 Viewed:  439 times
 File size:  248.91 KB
 Viewed:  765 times
Post18-07-2014, 9:33    Subject: Starter Motor Touran BRU Quote
It's starting again.
ATP's new, low-cost part is now locked.
The Plus power shoe didn't fit perfectly; a protrusion on the starter motor was in the way.
With a little bit of adjustment (to the cable), there's no problem.
The new starter is surprisingly quiet, and the BRU starts up incredibly fast, as is typical for a 1.9-liter engine.
As a family car with 260,000 km on the odometer, it still has some life left in it icon_smile.gif.
Translated on 11-09-2026, 3:18.
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts SDI Starter Motor - Replacement & Repair On-Board Diagnostics (OBD)
No new posts TDI Starter Compatibility: Find the Right One Diesel Engine Technology
No new posts Starter Motor Problems: Troubleshooting & Solutions Diesel Engine Technology
No new posts Replacing the starter motor on a Volkswagen Golf III TDI Diesel Engine Technology
