EDS at T5 GP, adjustable response?
Mc_Givertechnik
2010 Volkswagen T5
Post14-11-2014, 21:40    Subject: EDS at T5 GP, adjustable response? Quote
Hello!
Fundamental question: Can the responsiveness of the EDS be adjusted?
Reason:
Not only in my T5 GP, but also in some other T5 GP models, the EDS does not function at all. Once the T5 has driven on slippery surfaces with one wheel, it cannot get back under control. The EDS does not work. I am very disappointed with the functionality of the EDS in my T5 GP model 2011, compared to the T4, whose EDS always worked. None of the affected T5 GPs exhibit any errors or other malfunctions that could explain this behavior.
My ABS/ESP System:
Address 03: Brake Electronics (-----) Label file: RKS\7E0-907-37x-MK25AXT.clb
Part Number SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Encoding: 108724AD09A7089924A6907A6A6410
Operating number: WSC 02756 790 49164
VCID: 3666B5EB81DB68AE711-8063
No error codes found.
Greetings,
Peter
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Ist der obere Wendepunkt vom Wischer mit VCDS justierbar? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Ansprechverhalten bzw. Ladedruckaufbau Diesel Engine Technology
No new posts Brake response Transmission, Chassis, Body & Interior
No new posts Turbocharger Response: Ibiza 6K, AFN Engine Diesel Engine Technology
