chli1976 Profi-Schrauber
16-12-2014, 20:16 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
I installed a used ABS hydraulic unit in an A3 (year 2009), but I can't seem to bleed the air out of the system.
First, bleed the air using the air vent device: vo.li, vo.re, hi.li, hi.re.
Then try the old method once, then adjust the basic settings, then try both wheels on an axle at the same time, but don't combine this with applying pressure while the engine is running.
Does anyone have a detailed guide on how to perform the basic settings using VCDS, as it always seems to only refer to the front axle?
Hold the pedal down, the ABS pump will activate. After turning off the pump, open the bleed valves on the front calipers, then close them. Hold the pedal down again. The pump will activate, then release the pedal. Depress the pedal 10 times with the bleed valves closed, and it should start working again. Hold the pedal down, and the pump will activate for 10 seconds.
I hope I remembered correctly now.
VCDS
Translated on 25-10-2026, 17:48.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
16-12-2014, 22:37 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
When bleeding the system using a vacuum pump (pressure method), the pressure must not exceed 1 bar; otherwise, the valve block cannot be properly bled.
If all else fails, you can still manually vent the system with two people.
- Close all bleed valves... Pump the brake pedal to build pressure, hold the pedal down, and open the bleed valve until the pedal drops approximately 75%. Close the bleed valve, release the pedal, and repeat the process as many times as necessary. This ensures that fluid is forced from the reservoir into the system, rather than air being sucked back through the bleed valve during the release process, which can sometimes happen.
Of course, this applies to all four wheels.
You have mail.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 25-10-2026, 17:50.
17-12-2014, 6:03 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
I only vented it with 1 bar the first time; I'll try again with just under 1 bar.
Then, using the old method, with a second person in the car pumping, I bled the system.
Then, using a vacuum pump and additional pumps. However, the air hasn't been removed yet.
Thank you for the mail.
I recently installed a new water pump in a Touran. I bled the system using a vacuum pump, and it worked perfectly.
VCDS
Translated on 25-10-2026, 17:51.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
17-12-2014, 9:11 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
Quote: | | Does anyone have a detailed guide on how to perform a basic setting using VCDS, as it always only mentions the front ones. |
To my knowledge, there is text about this in the relevant window in VCDS. How to access the corresponding basic settings depends on the ABS/ESP control unit.
Autoscan?
Translated on 25-10-2026, 17:52.
Profile PM WWW Garage |
17-12-2014, 9:43 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
Yes, it is mentioned, but due to the limited number of positions that can be displayed here, it is not entirely clear to me.
Tuesday, December 16, 2014, 19:18:51:03029
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: DRV 14.10.0.0
Data as of: 20141115.
Vehicle Identification Number: WAUZZZ8P79A****** License Plate:
Mileage: 90,200 km. Repair order: HC.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Vehicle Identification Number: WAUZZZ8P79A017689
Mileage: 90,200 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
56-Radio -- Status: unreachable 1100
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module
Label file: DRV\03G-906-021-BLS.clb
Part number SW: 03G 906 056 R, HW: 03G 906 021 AB.
Part: R4 1.9L EDC G000SG 2916
Revision: --H08--- Serial Number: AUX7Z0H6FNH03U
Encoding: 0000071
Operating number: WSC 06314 000 00000
VCID: 36656F8B414CA891857-8063
"One error found:"
005660 - Spark plug, cylinder 3 (Q12)
P161C - 000 - Interruption.
Environmental conditions:
Error status: 01110000
Error priority: 3.
Error frequency: 1.
Lost Count: 255
Mileage: 90,174 km
Time: 0.
Date: 2014.12.16
Time: 05:23:52
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.86 V
Binary value: 00101100
Temperature: 14.4°C
Binary value: 00110000
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (-----)
Label file: DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AN, Hardware number: 1K0 907 379 AN.
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Encoding: 1142201209230001881104EC902200413800
Operating number: WSC 12345 123 12345
VCID: 7EF5B7ABE9FCA0D11D7-802B
No error codes found.
Address 08: Climate Control/Heating. Label file: DRV\8P0-820-043.lbl
Part number SW: 8P0 820 043 BG, Hardware number: 8P0 820 043 BG.
Component: Climate Control System H09 0100
Revision: 000606
Serial number: 8P0820043BG
Operating Number: WSC 00000 000 00000
VCID: 72ED939B6DA4F4B169F-8027
Address 09: Central Electronics
Label file: DRV\8P0-907-279-30-H.lbl
Part number SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: On-board network module H54 2801.
Revision: 00H54000 Serial Number: 00000008664320
Encoding: 14A82F8190141380EF00001C0000000000094A056401040300A800000000
Operating number: WSC 06314 000 08192
VCID: 489911733BB82E61E7B-801D
Subsystem 1 - Part number: 8P1 955 119 F
Label file: DRV\1KX-955-119.CLB
Component: Wiper blade AU350 H10 0040.
Encoding: 00056595
Address 15: Airbag (J234)
Label file: DRV\8P0-959-655-10.clb
Part number SW: 8P0 959 655 J, Hardware number: 8P0 959 655 J.
Component: Airbag AU1042 H06 0090
Revision: -------- Serial Number: 003000000000
Encoding: 303142383038303030354A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499F1477E8B2D769F85-801C
Crash sensor for driver-side side airbag:
Serial number: 3572DRB4000077CC810X
Crash sensor for the side airbag, passenger side:
Serial number: 3582DRB400007784CB2
Rear side airbag crash sensor (driver's side).
Serial number: 35128RB400003E77B94U
Rear side airbag crash sensor, passenger side.
Serial number: 35228RB400003E72746J
Crash sensor for front airbag, driver's side:
Serial number: 35547RB400003F73861N
Crash sensor for front airbag, passenger side:
Serial number: 35647RB400003F737E3X
Address 16: Steering wheel electronics
Label file: DRV\8P0-953-549-F.lbl
Part number SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Encoding: 0000042
VCID: 418F0C5718821F29205-8014
Address 17: Control panel module
Label file: DRV\8P0-920-xxx-17-MY8.clb
Part number SW: 8P0 920 931 S HW: 8P0 920 931 S
Bauteil: KOMBIINSTR. VDO H15 0830
Revision: D0H15005 Serial number: 2246H005016846
Coding: 0004128
Operating Number: WSC 37223 001 1048576
VCID: 4383065F029E0D39329-8016
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530-V3.clb
Part number SW: 1K0 907 530 Q, HW: 1K0 907 951.
Component: J533__Gateway H16 0202
Revision: H16 Serial Number: 2700K087040063
Encoding: E9807F060002022102
VCID: 356768875C4AA3898CD-8060
2 error codes found:
01305 - Data bus for infotainment system.
004 - No signal/communication.
Error status: 01100100
Error priority: 1.
Error frequency: 46.
Lost Count: 132
Mileage: 90,167 km
Time: 0.
Date: 2014.12.15
Time: 20:59:17
01304 - Radio
Error priority: 2.
Error frequency: 1.
Lost Count: 128
Mileage: 90,167 km
Time: 0.
Date: 2014.12.15
Time: 20:59:22
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Part number SW: 8P0 920 931 S, Hardware: 8P0 920 931 S.
Revision: D0H15005 Serial Number: AUX7Z0H6FNH03U
Address 42: Door electric, driver's side.
Label file: 8P0-959-801-MIN3.lbl
Part number SW: 8P0 959 801 K, Part number HW: 8P0 959 801 K.
Component: Door module H03 0060.
Encoding: 0000252
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K0 909 144 C
Component: EPS_ZFLS, Class 232, Part Number 2301.
Revision: 00H15000
Operating number: WSC 02069 000 90108
VCID: 2A5D4BFB85F4FC7111F-807F
Address 46: Comfort System
Label file: DRV\8P0-959-433.lbl
Part number: 8P0 959 433 L
Component: KSG H11 0080
Encoding: 1880200002186D0985054C8F0167
VCID: 458718470CAA33091CD-8010
Subsystem 1 - Component: Sounder (not mounted)
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE, not mounted.
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MIN3.lbl
Part number SW: 8P0 959 802 K, HW: 8P0 959 802 K.
Encoding: 0000252
VCID: 4481054307900A010B3-8011
Address 56: Radio.
unavailable
Address 62: Door electrical, left/right.
Label file: DRV\8P4-959-801.lbl
Part number SW: 8P4 959 801 E. Part number HW: 8P4 959 801 E.
Component: Door module H04 0040.
Coding: 0000216
Operating number: WSC 06314 000 1012544
Address 72: Door electrical, high, right.
Label file: DRV\8P4-959-802.lbl
Part number SW: 8P4 959 802 E
Part number HW: 8P4 959 802 E
Coding: 0000216
VCID: 428D035B1D84043139F-8017
VCDS
Translated on 25-10-2026, 18:17.
30-01-2015, 12:27 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
I've now installed a third used ABS unit, and the pressure point still isn't what it should be.
"In the second case, the error was a basic setting in the error memory. I then tried to adjust the intake and separation valves, but I got stuck when adjusting the separation valves, and the error memory then displayed an ABS operation error."
Now, with the third one, the control unit is working correctly, but there's no proper engagement point.
We started with a vacuum pump and two people, one at the front and one at the back, but no air is coming out anymore, but the bleeding point is still terrible.
Either there's another problem (with the master cylinder), or it's really just an air bubble that I can't get rid of.
Why would a new hydraulic unit arrive pre-filled and bled?
VCDS
Translated on 25-10-2026, 18:43.
Frankbe Blaumann
Joined: 12/07/2012 Posts: 51 Karma: +9 / -0 Location: Söhrewald 2015 Seat Leon Premium Support
31-01-2015, 6:06 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
Try bleeding the lines at the ABS unit first, and then at the wheel brake cylinders. I had a similar issue once with a Golf 4, and that helped.
Seat Leon 3 ST (5F)
2,0 TDI MKB:CUNA
Translated on 25-10-2026, 18:44.
Profile PM Garage |
31-01-2015, 6:52 Subject: ABS Hydraulic Replacement: A3 Always Has Air |
I've already tried that.
I left the lines that run from the ABS module to the wheel cylinders disconnected and waited until fluid stopped leaking out of them.
VCDS
Translated on 25-10-2026, 18:45.
