When is a differential pressure sensor dead?
Go to page: 1, 2  Next
Post21-07-2011, 9:35    Subject: When is a differential pressure sensor dead? Quote
Hi.
Based on which measured values is a differential pressure sensor G450 considered to be in need of replacement?
Do you have any offsets that are considered too large?
Or other, strange behavior.
"Mine has a different offset every day (sometimes 13, sometimes 9, etc.), and yesterday it surprised me while I was stationary, engine off, with a differential pressure of 2 mbar."
We've already established that these things age, not in terms of operating hours, but with the passage of time. The new location of the CRs is also noteworthy; instead of being mounted on the engine, they are now located on the body in a vibration-dampened position.
servusssss
Karma: +12 / -0   Thank you, like it!
Post21-07-2011, 11:38    Subject: When is a differential pressure sensor dead? Quote
On the Golf 6 with a 2.0 CR engine, the sensor is also mounted on the engine.
I received a new sensor after the differential pressure stopped changing.
See:
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
SG
Post27-09-2011, 14:14    Subject: When is a differential pressure sensor dead? Quote
For the Golf 6 with a 2.0 CR engine, is the sensor also mounted on the engine
Do you have a picture of it?
I saw him in a Golf, next to the engine!
Post12-10-2011, 9:52    Subject: When is a differential pressure sensor dead? Quote
Has anyone ever replaced this part "just in case" and noticed any improvements?
I have sensors operating with offsets of 13 mbar, -9 mbar, and -15 mbar.
I think I'll get a new one and see what happens.
Karma: +807 / -0   Thank you, like it!
Post12-10-2011, 10:19    Subject: When is a differential pressure sensor dead? Quote
Until the differential pressure sensor failed, I couldn't detect any abnormalities in my BRE.
Post12-10-2011, 13:36    Subject: When is a differential pressure sensor dead? Quote
... and the failure occurred suddenly and unexpectedly?
... and then the part stopped working?
michiglaser
2007 Audi A4 Avant
Post12-10-2011, 13:37    Subject: When is a differential pressure sensor dead? Quote
A badger (at the ASB - presumably a location) chewed through a hose connecting the DPF (Diesel Particulate Filter) to the differential pressure sensor.
Even then, there was no noticeable change in the way the car handled, only the engine check light was on.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
servusssss
Post18-10-2011, 16:29    Subject: When is a differential pressure sensor dead? Quote
Hi dieselmartin,
I need to correct myself; the sensor is mounted on the engine mount, not on the engine itself.
SG
 File name:  Diff_Markiert.jpg
 File size:  1 MB
 Downloaded:  32691 times
 File name:  Diff-Sen.jpg
 File size:  401.02 KB
 Downloaded:  21028 times
voodoo
Post18-10-2011, 20:31    Subject: When is a differential pressure sensor dead? Quote
My sensor for the pressure die is also mounted on the injection molding machine.
In the image on the top left:
[img][/img]
I replaced it at the same time, just to be on the safe side, while cleaning the DPF.
It has never been defective before.http://stefan.localh0rst.net/albums/album02/IMG_0044.sized.jpg{MARKER}
Post24-02-2014, 20:52    Subject: When is a differential pressure sensor dead? Quote
After several years, the sensor is probably still working, but I noticed today that there should be a difference when the engine is not running?!?
Address 01: Engine Control Module (03G 906 018 EM)
16:06:22 Block 067: Diesel particulate filter (exhaust values I).
106.5°C temperature before the turbocharger.
102.3°C temperature inside the particulate filter.
4.4 mbar Differential pressure, particulate filter
-4 mbar offset differential pressure.
16:06:22 Block 068: Particle filter (exhaust values II)
1.1% Loading coefficient.
36.97 Ash content
-12.8% Ash content.
16:06:22 Block 073: Particle filter (vehicle data)
1.0 l fuel consumption since regeneration.
21 km distance covered since regeneration.
0 h Time since regeneration
That means, yes, that he always appears fuller than he actually is icon_question.gif.
Post24-02-2014, 21:01    Subject: When is a differential pressure sensor dead? Quote
"Should" certainly not, the question is whether the small value has noticeable effects. icon_wink.gif
Post24-02-2014, 21:24    Subject: When is a differential pressure sensor dead? Quote
I had a balancing process running after the measured pressure of 4.4 mbar.
Later, after measuring with VCDS (for a certain number of hours), the results looked like this:
Code:
                Adresse 01: Motorelektronik  (03G 906 018 EM)
20:58:13 Block 067: Partikelfilter (Abgaswerte I)
  26.8°C  Temperatur vor Abgasturbolader
  24.4°C  Temperatur im Partikelfilter
  0.0 mbar  Druckdifferenz Partikelfilter
  -9 mbar  Offset Differenzdruck
20:58:13 Block 068: Partikelfilter (Abgaswerte II)
  1.1 %  Beladungs- koeffizient
  36.97  Aschemasse
  -12.8 %  Aschelernwert
20:58:13 Block 073: Partikelfilter (Fahrzeugdaten)
  1.0 l  Verbrauch seit Regeneration
  21 km  Strecke seit Regeneration
  0 h  Zeit seit Regeneration
MarcKoe likes this.
Post25-02-2014, 7:18    Subject: When is a differential pressure sensor dead? Quote
What exactly does the offset do at that point? It seems to have "rounded up" and included the 4.4...?
Post25-02-2014, 7:28    Subject: When is a differential pressure sensor dead? Quote
matthiasTDI96 wrote:
What exactly does the offset do at that point, and how did it "round up" and include the 4.4...?
I thought so too.
He had an offset of -4 and an incorrectly high value of 4.4.
To correct the measurement to 0, you need to subtract 4.4 from the already calculated -4, resulting in -8.4, which is approximately 9 mbar.
I've also seen readings as low as -13 mbar.
The offset is therefore constantly fluctuating, which contradicts the concept of "calibration" or "adjustment."
Because why should I have to "pair" the sensor via login 3060 if it's supposed to constantly provide different values, and the MSTG is supposed to automatically compensate for that?
...or is it actually not supposed to fluctuate, and therefore considered "unstable" and in need of replacement?
Post06-03-2014, 14:11    Subject: When is a differential pressure sensor dead? Quote
Haha.
Now it's weird again:
Code:
13:55:30 Block 067: Partikelfilter (Abgaswerte I)
  60.8°C  Temperatur vor Abgasturbolader
  57.6°C  Temperatur im Partikelfilter
  4.4 mbar  Druckdifferenz Partikelfilter
That means it will result in an offset of -13 millibars.
I think there will be a new sensor next time.
Post21-05-2014, 9:58    Subject: When is a differential pressure sensor dead? Quote
There have even been instances where the pressure reached as low as -16 mbar.
Code:
10:18:02 Block 067: Partikelfilter (Abgaswerte I)
  16.0°C  Temperatur vor Abgasturbolader
  19.9°C  Temperatur im Partikelfilter
  -16 mbar  Offset Differenzdruck
No new posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF differential pressure sensor output voltage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential Pressure Sensor Diesel Engine Technology
No new posts Differential Pressure Sensor T5 On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor: Explained Diesel Engine Technology
No new posts Offset always at -25.5 Diesel Engine Technology
