Differential Pressure Measurement at CJCD
Karma: +1359 / -0   Thank you, like it!
Post28-03-2015, 17:50    Subject: Differential Pressure Measurement at CJCD Quote
I previously thought that the soot load of the diesel particulate filter (DPF) was determined by measuring the pressure difference across the DPF. However, it seems that this can also be achieved by measuring the pressure difference against the outside air pressure.
In my specific CJCD system, the "differential pressure sensor" is only connected to the engine side of the DPF; the other connection on the sensor is just a short, open hose. The RLF (presumably a diagnostic tool) shows something different.
Translated on 04-08-2026, 5:17.
Karma: +807 / -0   Thank you, like it!
Post28-03-2015, 18:07    Subject: Differential Pressure Measurement at CJCD Quote
Correct, in a properly sized exhaust system, there isn't much pressure change after the DPF – and that small amount can be modeled using a calculation model. icon_wink.gif
Incidentally, a "calculation model" is a) cheaper than connecting to the DPF and b) more reliable because nothing can mechanically break.
Translated on 04-08-2026, 5:19.
Post29-03-2015, 10:34    Subject: Differential Pressure Measurement at CJCD Quote
"In principle, it is possible if you know the resistance of the rest of the exhaust system, the exhaust flow (based on exhaust temperature, air mass, and injection quantity), and the external pressure. The air pressure sensor is probably located in the engine control unit (ECU). There is no air pressure sensor shown in the wiring diagram."
Translated on 04-08-2026, 5:20.
Post29-03-2015, 11:34    Subject: Differential Pressure Measurement at CJCD Quote
The air pressure sensor is likely located in the MSG
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
Translated on 04-08-2026, 5:21.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
