Interior lighting failure after switching to LEDs
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
FuLLHDvs480p
Post29-07-2015, 23:09    Subject: Interior lighting failure after switching to LEDs Quote
I'm having the following problem. I want to replace the interior lighting in my Touran 1T2 with LED lights.
Unfortunately, I didn't have any success with that. After repeatedly trying different things, the light bulbs eventually started burning out as well.
I'm assuming that I had installed an LED incorrectly, which caused a short circuit. icon_question.gif icon_confused.gif
Currently, all the lights are incandescent bulbs. I'm experiencing the following issue with the central electrical system:
Code:
Adresse 09: Zentralelektrik       Labeldatei: DRV\3C0-937-049-30-H.lbl
   Steuergerät-Teilenummer: 3C8 937 049 E    HW: 3C8 937 049 E
  Bauteil und/oder Version: Bordnetz-SG     H54 2602
                 Codierung: 018D0F2100040F0047120C000000000000097F075C00012C000000000000
            Betriebsnummer: WSC 01324 020 00200
  Erweiterte Informationen: 1T1955119   Wischer 150110 021  0512
                      VCID: 3362BD7D52FC8CB9A3D-8066
Fehlercodes wurden gelöscht.
1 Fehler gefunden:
00059 - Klemme 30 für Innenbeleuchtung
            012 - elektrischer Fehler im Stromkreis
             Umgebungsbedingungen:
                    Fehlerstatus: 01101100
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 62
                    Kilometerstand: 67493 km
                    Zeitangabe: 0
                        ein
                    Spannung: 12.25 V
                        ein
                        aus
                        aus
                        aus
                        aus
When I try to delete the error, it reappears immediately.
Does anyone have any suggestions on what else I could check? Perhaps some fuses?
Best regards, Timo.
Translated on 15-07-2026, 7:52.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Steffen W likes this.
Post30-07-2015, 6:38    Subject: Interior lighting failure after switching to LEDs Quote
Please check fuse SC46 (7.5A) in the footwell.
Click.
As it turns out, the fuse SC46 (7.5A) located in the footwell was blown. This fuse is responsible for supplying power from the body control module to terminal 30 for the interior lighting.
Translated on 15-07-2026, 7:54.
FuLLHDvs480p
Post30-07-2015, 17:03    Subject: Interior lighting failure after switching to LEDs Quote
Thank you, that one was defective. Finally, there's light in the car again icon_biggrin.gif.
Translated on 15-07-2026, 7:55.
Karma: +807 / -0   Thank you, like it!
Post30-07-2015, 17:57    Subject: Interior lighting failure after switching to LEDs Quote
Thank you for your feedback!
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Warm Start Issues After MSG Swap 1Z to AFN On-Board Diagnostics (OBD)
No new posts DPF Replacement: Adjusting Ash Mass On-Board Diagnostics (OBD)
No new posts Problems after turbo replacement Upload
No new posts Coolant loss in CFFB engines after EGR valve replacement Diesel Engine Technology
