Disable System Start/Stop Feature
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post18-04-2016, 20:40    Subject: Disable System Start/Stop Feature Quote
"With my Sharan 7N, manufactured in 2011, I'm experiencing an issue where the battery seems to be failing, and the battery management system is disabling the automatic features."
I wanted to check the encoding settings in the code, but I can't seem to change them (see Screenshot).
 File size:  32.97 KB
 Viewed:  8247 times
Translated on 25-09-2026, 17:06.
Post18-04-2016, 20:58    Subject: Disable System Start/Stop Feature Quote
You need to set the WSC, importer number, etc. in the VCDS program settings. If you don't have the official numbers: perform an Autoscan. icon_wink.gif
Post18-04-2016, 21:47    Subject: Disable System Start/Stop Feature Quote
Do you have a new Sharan or VCDS? If it's the latter, familiarize yourself with the forum and the instructions. Especially when you're modifying something, make sure you know what you're doing.
Translated on 25-09-2026, 17:07.
Post18-04-2016, 21:50    Subject: Disable System Start/Stop Feature Quote
matthiasTDI96 wrote:
Do you have a new Sharan or VCDS? If it's the latter, familiarize yourself with the forum and the instructions. Especially when you're modifying something, make sure you know what you're doing....
And it's best to archive a pristine, factory-fresh scan, so you can always revert to the original state. icon_idea.gif
vag-driver
Post18-04-2016, 22:39    Subject: Disable System Start/Stop Feature Quote
I bought the Sharan new. I've had VCDS for a while. However, I don't know all of its features. I'm learning about it problem by problem icon_cool.gif.
I noticed that the battery management system is configured for a wet cell battery. I wanted to change that to AGM. The error memory is empty, so it's likely either a misconfiguration or a weakening battery.
Can I make the change if I enter the WSC code?
Translated on 25-09-2026, 17:08.
Post19-04-2016, 8:53    Subject: Disable System Start/Stop Feature Quote
Okay, let's start with the automatic scan. This will ensure you have a backup and also allow you to demonstrate the process here.
Regardless of what's being coded, first determine exactly what type of battery is currently installed. It's very important that the coding matches the battery type.
Furthermore, it's important to mention the manual. Also, please read what Rainer wrote, or consider the note provided by VCDS. The coding process often requires a number related to the workshop, device, etc., exactly as stated in the message, and also as found in the manual and under settings.
Translated on 25-09-2026, 17:09.
vag-driver
Post19-04-2016, 10:03    Subject: Disable System Start/Stop Feature Quote
There are no more errors/entries. Unfortunately, I don't have a current scan available at the moment.
Saturday, April 2, 2016, 8:08:20 PM: 19385
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 15.7.4.1
Data as of: 20160223.
Vehicle Identification Number: WVWZZZ7NZBV023072
License plate: xyz
Mileage: 96390 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 7N (7N0)
Scan: 01 03 05 08 09 10 15 16 17 18 19 25 2B 36 37 42 44 46 47 4F
52 53 55 56 61 62 69 6C 6D 72 77 BE BF
Mileage: 96390 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
2B steering column lock. -- Status: OK 0000.
36-seat adjustable passenger seat -- Status: OK 0000.
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: Error 0010.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
6C Rear-view camera -- Status: OK 0000
Rear hatch -- Status: Error 0010.
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
Rear left sliding door -- Status: OK.
Rear right sliding door -- Status: OK 0000.
Address 01: Engine Control Module (J623-CFGB)
Label file: DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 F, HW: 03L 907 309 Q.
Component: R4 2.0L EDC H24 0257
Revision: 44H24--- Serial number:
Encoding: 0019001A043401080000
Operating number: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018F 003003
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 2D573FB17C5A8756E5-8078
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: 7N0-614-109.clb
Part number SW: 7N0 614 109 L, HW: 7N0 614 109 L.
Component: J104 C3 450M VDC1 0008
Revision: --H07--- Serial number: 00000003531178
Encoding: 0023072
Operating number: WSC 00020 790 00000
VCID: 366510DD410CC48E94-8062
"One error found:"
02214 - Tire pressure warning.
002 - Lower limit exceeded - Intermittent.
Environmental conditions:
Error status: 00100010
Error priority: 6
Error frequency: 8
Lost Count: 229
Mileage: 96274 km
Time: 0.
Date: 2016.04.01
Time: 14:03:23
Speed: 125.0 km/h
Hex Value: 0x0000
Binary value: 00000000 00000000
Voltage: 14.50 V
Binary value: 00011111
Quantity: 185
Hex Value: 0x0000
Address 05: Access/Startup Authorization (J518)
Label file: DRV\5K0-959-434.clb
Part number SW: 5K0 959 434 A, Part number HW: 5K0 959 434 A.
Part number: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial Number: 0140603123
Encoding: 03100C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 336329C99A7ED1A6B3-8066
Address 08: Climate Control/Heating (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 J, Part number HW: 5K0 907 044 J.
Part: Clima-Sharan H11 0104
Revision: 00002001
Encoding: 0000000109
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis_VW36.rod
VCID: 326D2CCD6564D8AEB8-8066
Slave 1:
Subsystem 1 - Part number SW: 7N0 907 049 B, HW: 7N0 907 049 B.
Component: KBT-H 004 0102
Serial number: 20101220000000011735
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 087 M, Part number HW: 5K0 937 087 M.
Component: BCM PQ35 H 011 0046
Revision: BE011001
Encoding: 40510A3B8925F3C0500800C0740009E443551408676D25F2E4808700A2C1
VCID: 3F8B75F9AE3605C647-806A
Subsystem 1 - Part number SW: 7N1 955 119 A, HW: 7N1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 110905 31 0032
Encoding: 000D9D
Subsystem 2 - Part number SW: 7N0 955 559 HW: 7N0 955 559 Label file: DRV\7N0-955-559.CLB
Component: RLFS 021 0022
Encoding: 0380BB
Subsystem 3 - Part number: 7N0 951 171.
Component: DWA sensor 00 002 0205.
Encoding: 000000
Subsystem 4 - Part number: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Encoding: 000000
Address 10: Parking Assist 2 (J446)
Label file: DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 HW: 7N0 919 475
Part: PARKING ASSIST 8K H04 0010
Revision: -------- Serial Number: 80231034802665
Encoding: 318001
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 78F9DEE5C398F2FE46-802C
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part number SW: 7N0 959 655 B, Hardware: 7N0 959 655 B.
Part number: VW10Airbag01L H07 0013
Serial number: 003GFPR2BKD3
Encoding: 00314C
ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3E7508FDA13C0CCE4C-806A
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60A4062A139DP
Encoding: 000000
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: --- HW: ---
Component: S. Sensor, passenger side --- ---
Serial number: 3503ETS6013C227139DC
Encoding: 000000
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60B0E429139DQ
Encoding: 000000
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: --- HW: ---
Component: S. Sensor, Passenger Side. --- ---
Serial number: 3523ETS606E783913DD
Encoding: 000000
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60EF6F3913DD0
Encoding: 000000
Address 16: Steering wheel electronics (J527)
Label file: DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 BM, HW: 5K0 953 569 L.
Component: STEERING MODULE 009 0136
Revision: FF010039 Serial number: 20101213300280
Encoding: 110A240000
Operating number: WSC 40517 000 1048576
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 76E5D0DDC98C848E54-8022
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D, HW: 3C8 959 537 D, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 17: Control panel module (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 7N0 920 870 A, Hardware: 7N0 920 870 A.
Component: KOMBI H20 0420
Serial number: 00000000000000
Encoding: 140F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 306926C56B68EABECE-8064
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 A
Component: Portable heater 043 4730
Revision: 00043000 Serial number: 09022127000000
Encoding: 0031142
VCID: 336329C9527ED1A6B3-8066
Address 19: Diagnostic interface (J533)
Label file: DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 D, HW: 1K0 907 951.
Component: J533 Gateway H35 0614.
Revision: H35
Serial number: 041210F2003181
Encoding: 468002
Operating number: WSC 00000 864 716674
VCID: 316F23C16862E3B6C1-8064
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234
Part number HW: 5K0 953 234
Component: IMMO H20 0420
Serial number:
Encoding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADDF4AD8D34506EC0-803E
Address 2B: Steering column lock. (J764)
Label file: DRV\5K0-905-861.clb
Part number SW: 5K0 905 861 A, Part number HW: 5K0 905 861 A.
Component: ELV-PQ35 H20 0220
Revision: 00000000 Serial number: 10000090905004
Encoding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E5538BD715CFC4EDC-807A
Address 36: Seat adjustment for driver (J810)
Label file: 3C0-959-760.lbl
Part number SW: 3C8 959 760 A, HW: 3C8 959 760 A.
Component: Seat Memory. Part Number: H05 2201.
Revision: 00H05000
Encoding: 000018
Operating number: WSC 12336 024 394758
VCID: 336329C9927ED1A6B3-8066
Address 37: Navigation (J0506)
Label file: DRV\1T0-035-680.clb
Part number SW: 1T0 035 680 C, HW: 1T0 035 680 C.
Component: RNS-MID H42 2720
Revision: AB001001 Serial Number: VWZ6Z7K4353137
Encoding: 06050002010000A000
VCID: 2E5538BD795CFC4EDC-807A
Address 42: Door electrical driver (J386)
Label file: 7N0-959-793.clb
Part number SW: 7N0 959 793 E, HW: 7N0 959 793 A.
Component: TSG FA H04 0400
Revision: Serial number: 0000110558255
Encoding: 01153E20DE00411001
VCID: 44817A15C7D0661E1A-8010
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 L, HW: 5N1 909 148 G.
Component: J500__APA-BS, Class 325, 0802.
Revision: 1AH03729 Serial Number: 00103480158201
Coding: 0000258
VCID: 3B7301E97A2E19E66B-806E
Address 47: Soundsystem (R12) Label file: 5K0-035-456.clb
Part number SW: 5K0 035 456 A, HW: 5K0 035 456 A.
Component: Corporate Amplifier 8K 0180.
Revision: -------- Serial Number: BP218809236600
ASAM Dataset: EV_AudioAmplifier8ChannelBNO1 A01003
ROD: EV_AudioAmplifier8ChannelBNO1.rod
VCID: 2859CEA553B8A27E16-807C
Address 4F: Central Electricity II (J520)
Label file: DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 1K0 907 951.
Component: EZE_2 H35 0614
Revision: H35
Encoding: 050B0500
VCID: 6FEBE5B9BED6B54697-803A
Subsystem 1 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Component: J394EE20SKB13 H02 0220
Address 52: Power door lock, front passenger side (J387)
Label file: 7N0-959-792.clb
Part number SW: 7N0 959 792 E, HW: 7N0 959 792 A.
Component: TSG BF H04 0400
Revision: Serial number: 0000110694398
VCID: 43837909C2DE612623-8016
Address 53: Parking brake
Label file: DRV\3AA-907-801.clb
Part number SW: 3AA 907 801 D, Hardware: 3AA 907 801 D.
Part number: J540 EPB4 VW-53083 0006.
Revision: H18 Serial Number: 00000000131217
Encoding: 0024067
VCID: 326D2CCDAD64D8AEB8-8066
Address 55: Headlight range control. Label file: DRV\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 D, Hardware: 5M0 907 357 D.
Component: AFS Control Unit 0149
Revision: 00H04000 Serial Number:
Encoding: 3555545
VCID: 356717D15C0ACF969D-8060
Subsystem 1 - Part number: 1T0 941 329
Label file: 3D0-941-329.CLB
Component: AFS-List Module l 0001
Encoding: 00000054
Subsystem 2 - Part number: 1T0 941 329
Component: AFS-Lst. module r 0001
Encoding: 00000054
"One error found:"
02236 - Static curve light, right side (M52).
011 - Interruption - Sporadic.
Error status: 00101011
Error priority: 3
Error frequency: 1.
Lost Count: 228
Mileage: 96,250 km
Time: 0.
Date: 2016.03.31
Time: 15:42:13
Voltage: 14.48 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio (J0506) Label file: DRV\1T0-035-680.clb
Address 61: Battery Management (J840)
Label file: DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 1K0 907 951.
Component: Battery management system H35 0614.
Encoding: 030B085A
VCID: 71EFE3C1A8E2A3B681-8024
Subsystem 1 - Part number SW: 1K0 915 181 F, HW: 1K0 915 181 A.
Component: J367-BDM H07 0150
Address 62: Door electric, left/right (J388) Label file: 7N0-959-794.clb
Part number SW: 7N0 959 794 F, HW: 7N0 959 795 B.
Component: TSG HL H03 0400
Revision: Serial number: 0000111312028
Encoding: 01007C200000411001
VCID: 4685601DF1EC540E04-8012
Address 69: Trailer (J345) Label file: DRV\7N0-907-383.clb
Part number SW: 7N0 907 383 HW: 7N0 907 383
Component: Trailer H07 0101
Revision: 3I001002 Serial number: 00000138883202
Encoding: 410C040001000000
VCID: 73E3E9C9D2FE91A673-8026
Address 6C: Rear view camera
Label file: DRV\5N0-907-441.clb
Part number SW: 7N0 907 441, HW: 7N0 907 441.
Part: J772__Rearview 0020
Revision: 00H08000 Serial Number: 525PA8-J0Y0329
Encoding: 0030011
VCID: 6ED5F8BD79DCBC4E9C-803A
Address 6D: Rear hatch (----)
Label file: DRV\7N0-959-107.clb
Part number SW: 7N0 959 107 B, HW: 7N0 959 107 A.
Component: HDSG Module H11 0803
Revision: 41011001 Serial number: 330000559
Encoding: 0733334003
ASAM Dataset: EV_HDSGVW428 201133
ROD: EV_HDSGVW428_SE36.rod
VCID: 366510DD890CC48E94-8062
"One error found:"
0004 - Basic calibration not performed.
B2010 00 [137] - -
Warning light ON - confirmed - checked since last reset.
Error status: 00000001
Error priority: 1.
Error frequency: 1.
Lost Count: 188
Mileage: 96,250 km
Date: 2016.03.31
Time: 15:44:16
Address 72: Door electric strike, high, right (J389)
Component: TSG HR H03 0400
Revision: Serial number: 0000111314705
Address 77: Phone (J412)
Label file: DRV\3C8-035-730-A.clb
Part number SW: 5N0 035 730 D, Hardware: 5N0 035 730 D.
Component: Telephone 009 0511
Revision: -------- Serial Number: 35909603087080
Encoding: 020100000100000000010000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SE36.rod
VCID: 295FCBA148B29B7609-807C
Address BE: Rear left sliding door (J558)
Label file: 7N0-959-244.clb
Part number SW: 7N0 959 244
Part number HW: 7N0 959 244
Component: Sliding door_l 005 2213
Serial number: 10481927.
ASAM Dataset: EV_AST A03002
ROD: EV_AST.rod
Address BF: Rear right sliding door (J731)
Component: Sliding door_r 005 2213
Serial number: 10481904.
ROD: EV_AST.rod
End----------------------------(Duration: 05:22)-----------------------------
It comes with a genuine VW VARTA AGM battery, not a conventional wet cell battery.
Translated on 25-09-2026, 18:03.
vag-driver
Post19-04-2016, 22:51    Subject: Disable System Start/Stop Feature Quote
It seems my battery maintenance is starting to have an effect. The engine is now shutting off again in stop-and-go traffic. However, the battery management system's coding should still be adjusted to match the installed battery.
Post20-04-2016, 9:53    Subject: Disable System Start/Stop Feature Quote
Before I make any changes, I would first check if the coding is standard and compare it with identical vehicles.
Because neither control units nor diagnostic programs are always error-free. You are assuming that they are, but that is not true.
The battery management system in my car has always shown a battery internal resistance of 4 ohms. This is NOT due to the diagnostic software (tested with other control units and the same messages). With an internal resistance of 4 ohms, my car would not even start.
Translated on 25-09-2026, 18:04.
vag-driver
Post20-04-2016, 10:07    Subject: Disable System Start/Stop Feature Quote
"Thank you. That's a good point that I can certainly address. Both Sharan models are, of course, equipped with the Start/Stop automatic system."
Compared to this, you can see that the other one has been encoded as an AGM. Which is also correct.
###############My Sharan####################################
Part number SW: 7N0 907 534, Part number HW: 1K0 907 951.
Encoding: 030B085A
Operating number: WSC 00000 864 716674.
###############other Sharan####################################
Serial number: 190211F2000590
Encoding: 030B185A
Translated on 25-09-2026, 18:07.
vag-driver
Post21-04-2016, 18:46    Subject: Disable System Start/Stop Feature Quote
During the long coding process, I also noticed that a JCI battery was installed, not a Varta, as specified.
How can I install it correctly? And also, make sure to select the AGM battery type.
Translated on 25-09-2026, 18:10.
Post21-04-2016, 19:23    Subject: Disable System Start/Stop Feature Quote
How can I set this up correctly? And of course, also select the correct battery type, which is AGM.
Well, the assistant should go through all the bytes of the long code and check for plausibility.
It has been observed that you can navigate "right" within the long encoding. It's not as if you always remain at the beginning of the byte...
Translated on 25-09-2026, 18:11.
vag-driver
Post21-04-2016, 19:51    Subject: Disable System Start/Stop Feature Quote
I can't set those values because the software doesn't allow that encoding. However, it might not actually have any effect.
Above, I compared two log files with different encodings.
Translated on 25-09-2026, 18:12.
Post21-04-2016, 21:31    Subject: Disable System Start/Stop Feature Quote
Have you configured the WSC, importer number, etc. in the VCDS program settings, as mentioned in the dialogue in the image above?
vag-driver
Post21-04-2016, 22:05    Subject: Disable System Start/Stop Feature Quote
Not yet. I'll try that tomorrow and let you know how it goes. In the meantime, I've also read posts in other VCDS forums where the battery type is coded as "wet cell" instead of "AGM."
It's possible that there's a defect from the factory. Or perhaps the setting has no effect.
Translated on 25-09-2026, 18:13.
vag-driver
Post22-04-2016, 9:50    Subject: Disable System Start/Stop Feature Quote
Based on the Screenshot, it's clear that the device number is incorrect.
What does this mean, and where can I get the correct one? Has the SG (presumably a component) ever been replaced without being coded?
 File size:  74.76 KB
 Viewed:  1760 times
Translated on 25-09-2026, 18:14.
No new posts Error code P2177 - Lean condition system during idle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2178 - Engine running too lean Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Airbag malfunction -> does this disable the system? On-Board Diagnostics (OBD)
No new posts Skoda Superb 3T: Start-Stop System On-Board Diagnostics (OBD)
No new posts Disable Audi A4 8W Start Stop System On-Board Diagnostics (OBD)
No new posts Start/Stop is unavailable, what does the measurement bloc... On-Board Diagnostics (OBD)
