Diesel Filter CFFB - Buy Online Now!
Post18-06-2015, 19:48    Subject: Diesel Filter CFFB - Buy Online Now! Quote
Is there a trick to closing the diesel filter on the CFFB engine? The cap is incredibly difficult to tighten.
 Dieselfilter mit O-Ring im Deckel, Motor 2.0 TDI CFFB.
 File size:  1.33 MB
 Viewed:  8281 times
Translated on 07-08-2026, 14:17.
findus170
dieselschrauber likes this.
Post18-06-2015, 19:56    Subject: Diesel Filter CFFB - Buy Online Now! Quote
Lubricate the rubber band and use wood to propel it.
Don't overtighten the screws; the flange will warp, and it will never seal properly again.
VW ID 7 GTX
Translated on 07-08-2026, 14:18.
chli1976
Karma: +185 / -0   Thank you, like it!
Post18-06-2015, 21:43    Subject: Diesel Filter CFFB - Buy Online Now! Quote
I always use screws and have never had a leak.
Make sure to lubricate the sealing ring properly, and then rotate each screw a quarter to half turn in a circular pattern.
VCDS
Post18-06-2015, 22:50    Subject: Diesel Filter CFFB - Buy Online Now! Quote
Always do it with the screws and I've never had a leak.
Lubricate the sealing ring properly and then rotate each screw a quarter to half turn in a circular motion
icon_smile_thumb_up.gif ... there are enough screws available. You just have to be careful when doing it.
Translated on 07-08-2026, 14:19.
Post18-06-2015, 23:25    Subject: Diesel Filter CFFB - Buy Online Now! Quote
findus170 wrote:
Grease the rubber ring and push it down with wood.
Don't try to tighten it by pulling on the screws; the flange will warp, and then it will never seal again.
chli1976 wrote:
Always do it using the screws, and I've never had a leak.
-1... These things are extremely sensitive; I've even made one leak myself despite being very careful.
I'll never do that again; I'll only put the screws in after the lid is properly aligned.
Translated on 07-08-2026, 14:20.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post19-06-2015, 8:33    Subject: Diesel Filter CFFB - Buy Online Now! Translating...
[Translating...]
http://www.klann-online.de/de/Produkte/Webkatalog/Produktkarte/tabid/208/eid/27995/Default.aspx
Passat Variant BGW 2005
vwSchrauber
Karma: +42 / -0   Thank you, like it!
Post19-06-2015, 10:02    Subject: Diesel Filter CFFB - Buy Online Now! Quote
-1... These things are extremely sensitive; I've even damaged one myself, despite being very careful.
I will never do that again; the screws won't go in until the lid is properly seated!
Assuming you can still get the screws in, even with the offset angle.
Always tighten the screws gradually, while simultaneously applying pressure... I haven't broken any yet icon_wink.gif.
Translated on 07-08-2026, 14:22.
Post19-06-2015, 10:54    Subject: Diesel Filter CFFB - Buy Online Now! Quote
Okay, thanks! Lubricating also helped me a bit. I then used pliers and some wiggling to push the filter in piece by piece, and the rest was done with the screws.
I don't consider this to be a very well-designed component compared to the other filters that are completely replaced.
Translated on 07-08-2026, 14:23.
Post03-07-2015, 23:35    Subject: Diesel Filter CFFB - Buy Online Now! Quote
I apply a thin layer of fresh motor oil to the gasket and the gasket's seating surface on the housing, and then I press the cover down with my bare hand - it works great this way. icon_wink.gif
Note: I use the oil that also goes into the engine for this purpose. icon_idea.gif
Translated on 07-08-2026, 14:24.
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Problem mit AGR bei 2.0 TDI - CFFB Diesel Engine Technology
No new posts 2.0 tdi CFFB DPF gereinigt Diesel Engine Technology
No new posts Rumbling ticking sounds, Sharan 7N CFFB Diesel Engine Technology
No new posts DPF regeneration every 600km, 2.0 TDI CFFB Diesel Engine Technology
