Audi A6 4B, year 2003 - how to properly read the diagnostic data?
Go to page: 1, 2  Next
DirkC4
Post09-10-2014, 12:20    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
I'm a bit lost right now.
(Admittedly, older Audis are more my area of expertise.)
Okay, here's the translation:
"An Audi A6 4B model from 2003 (manual transmission) has both Dual K-Line and CAN, correct?"
I have this interface here:
--> http://shop.dieselschrauber.de/vcds-obd2-pro-diagnosis-kkl-can-p-46.php
I can read data from engine control units (ECUs), window/door control modules, instrument clusters, and airbags.
(likely uses Dual-K and/or CAN?)
The other items apparently require an L-type cable.
ZV: Central locking
LWR: Heated rear window
Komfort-STG: Comfort control unit
RNS/D: Navigation system
I can't read this - why not?
Do I need to switch or connect anything so that the K2 line of the interface communicates with the L line?
Wiesel
Post09-10-2014, 12:37    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Hello Dirk,
The interface should ideally cover everything from the Golf 3 generation onwards.
that has been released by VW/Audi/Seat/Skoda (plus some older items).
The L-Line designation should have disappeared from vehicles since the early 1990s (the last millennium).
Have you checked to see if all the fuses are in good condition?
What does a car scan report show when using the appropriate devices?
Here's a scan of a colleague's 4B exam.
Vehicle type: 4B (4B - Audi A6 C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Vehicle Identification Number: WAUZZZ4Bxxxxxxx
Mileage: 277,400 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: RKS\038-906-019-AVF.lbl
Part number: 038 906 019 LM
Component: 1.9L R4 EDC 0000SG 5646.
Coding: 00002
Operating number: WSC 65170
WAUZZZ4Bxxxx AUZ5Zxxx
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake electronics. Label file: RKS\4B0-614-517.lbl.
Part number: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 06255
Operating number: WSC 02334
Address 08: Climate/Heating Control. Label file: RKS\4B0-820-043-MY2.lbl
Part number: 4B0 820 043 AP
Component: A6 Climate Control System, Part Number 0208.
Coding: 00103
Operating Number: WSC 00000
Address 15: Airbag
Label file: RKS\4B0-959-655-AI84.lbl
Part number: 4B0 959 655 AA
Part: Airbag 8.4EP 1002
Coding: 0000706
Operating number: WSC 02334 785 00200
Address 17: Terminal block insert
Label file: RKS\4B0-920-xxx-17.lbl
Part number: 4B0 920 900 Q
Part: COMBINATION INSTRUMENT + REMOTE CONTROL. M73 D07.
Coding: 00040
WAUZZZ4Bxxx AUZ5Zxxx
Address 35: Central locking
Label file: RKS\4B0-962-258.lbl
Part number: 4B0 962 258 L
Component: Central locking system D38.
Coding: 06721
Address 55: Headlight range adjustment. Label file: RKS\4Z7-907-357.lbl
Part number: 4Z7 907 357.
Component: Dynamic LWR, D09.
Coding: 00040
Address: 56; Radio. Label file: RKS\8E0-035-1xx-56.lbl.
Part number: 4B0 035 186 S
Part: concert II GRO 0001
Coding: 02001
Address 76: Parking Assist
Label file: RKS\8Z0-919-283.lbl
Part number: 8Z0 919 283
Component: Parking system. A6 RDW D08
Coding: 10116
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Micha
DirkC4
Post09-10-2014, 14:41    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Wiesel wrote:
The L-Line should have disappeared from the vehicles since the early 1990s (the last millennium).
I honestly don't understand that statement because:
In the circuit diagram of the aforementioned. In vehicles (model year 2003), the L-line is indicated at the diagnostic connector (pin 15) with a green/blue wire.
and this also leads to various STGs, such as:
Climate control, multi-function steering wheel, central locking, tire pressure monitoring system, navigation system, radio, automatic headlight range control, and parking assistance.
Wiesel
Post09-10-2014, 15:06    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Hello Dirk,
Originally, the diagnostic process required two lines (K and L) per control unit.
"K" stands for the actual communication, and "L" is used to initiate the diagnosis (another term for "L" is "stimulation").
Since the L-line is no longer needed, pin 15 is also not used (for this year's models).
a K-line (the second K in KKL).
The background is that the number of control units per K-line is limited.
Ideally, your interface should work seamlessly without any external intervention, even on...
to communicate with this line... or do you have a solution for operating with the old...
Audi (AAT and similar models - these still had an L line) might have something in the VCDS settings.
adapted?
Then, if necessary, reinstall VCDS in a separate branch, so that...
The system operates using default settings.
Micha
DirkC4
Post09-10-2014, 16:20    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Is the designation "L-line" in the Audi wiring diagram incorrect?
Tried it again just now:
Now, strangely enough, it's working perfectly. icon_idea.gif icon_question.gif icon_rolleyes.gif
Post09-10-2014, 16:29    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
DirkC4 wrote:
So, is the designation "L-Leitung" in the Audi wiring diagram incorrect?
Now, surprisingly, it's working perfectly. icon_idea.gif icon_question.gif icon_rolleyes.gif
Yes, you don't have an L-line for that; you have a second one. K-line.
Wiesel
Post09-10-2014, 17:14    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
The second "K" is only not present in the ISO9141 standard.
defined. Therefore, it continues to appear in the plans.
Turn on the L.
DirkC4
Post10-10-2014, 15:45    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Thank you very much, very interesting.
Is there a place within VCDS where it's specified which control unit belongs to which K-segment (K or K2)?
(so that the software or adapter "knows" whether it should do the corresponding thing). Should the STG be addressed via pin 7 or pin 15?
or will everything simply be "scanned" sequentially, K, K2, CAN?
When I look at the "Autoscan.txt" file, it doesn't seem to be the case... (?)
Post10-10-2014, 17:49    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
It simply queries both K-lines, and the respective control unit (with its corresponding address) then responds.
Wiesel
Post10-10-2014, 17:51    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
...is there actually a place in VCDS where it's specified which control unit belongs to which K-segment (K or K2)?...
It's (actually) not necessary. The question is always asked on both lines, and because of that...
Each control unit address can only occur once in the vehicle, and therefore...
provide an answer. Logically speaking, one could say that the lines are...
parallel connected (which is not electrically correct, as the structure would then not be...)
The standard should be met, and the L-line function should not be available for older vehicles.
(which would be feasible).
Micha
KANE326
Post08-07-2015, 22:10    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
I need to revisit this topic.
"On my RS6 4B, manufactured in 03/2003, I can only access the engine, transmission, brakes, airbag, and instrument cluster modules when the engine is running. Otherwise, there is no communication when the ignition is on!" Furthermore, I simply can't figure out things like, for example, the central control unit (35), headlight range adjustment, etc.! icon_mad.gif
The central control unit is probably acting up again. The remote central locking system is no longer working (and cannot be reprogrammed), the interior lighting is malfunctioning (even though the doors are being recognized), and the diagnostic system is not working.
I would be very grateful for any tips!
Greetings.
Post09-07-2015, 9:16    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Are there any errors stored in the other control units that would suggest communication problems?
In control units that communicate via the K-line, a control unit with a hardware defect can also disrupt communication with other units.
KANE326
Post10-07-2015, 6:43    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
No communication errors. But on the K-line with the central locking control unit, the air conditioning is also connected, and I can't figure out how to access that either.
But why does the diagnosis on the other K-line only start when the engine is running?
Post10-07-2015, 9:28    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Check the operating voltage displayed in the measurement data blocks of the respective control units. Specifically, when the engine is off (if it doesn't work).
"In addition, please provide the bit rates that are briefly displayed in the upper left corner of VCDS during the connection setup, for example, 9587 for a control unit that communicates via K-Line at 9600 bits per second."
KANE326
Post11-07-2015, 6:30    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Okay, the engine has the code B 10240 on it.
There is no communication with the parking assist system in the control panel housing.
The CAN interfaces are input/output and operate in a two-wire configuration.
I'm going to replace the central vehicle control unit.
Post11-07-2015, 8:49    Subject: Audi A6 4B, year 2003 - how to properly read the diagnostic data? Quote
Please wait before exchanging anything; I absolutely need additional data from other control units. You can also test it on other vehicles if you like.
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2003, Hands-free device malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, noises from the front of the car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Looking for Audi A4, year 2003, with VAG COM / Channel Ov... On-Board Diagnostics (OBD)
No new posts Power steering failure Audi A3, year 2003 Transmission, Chassis, Body & Interior
No new posts Audi A3 8L: Chorus II Radio Problem (2003) Transmission, Chassis, Body & Interior
No new posts Reading out an Audi A2 with VAG 1551? On-Board Diagnostics (OBD)
