Intermittent lack of boost pressure, 1.8T AUM
BartliTECH
1999 Audi A3
Post15-03-2017, 21:31    Subject: Intermittent lack of boost pressure, 1.8T AUM Quote
Good evening, everyone.
Here's the translation:
"This is about a VW Golf 4 GTI 1.8T with the AUM engine."
I'm experiencing a problem where I sometimes have no power or boost pressure. When I then turn off the engine and restart it, it has full power again.
I have the following error codes in the engine control unit's memory:
• Pressure drop at the loader - throttle valve.
• Engine control unit (ECU) locked, intermittent.
Could the problem be related to the N75 boost pressure control valve?
How can I measure that?
Because the boom on the loader should actually be working again if it restarts and functions properly.
Karma: +595 / -0   Thank you, like it!
Post15-03-2017, 22:25    Subject: Intermittent lack of boost pressure, 1.8T AUM Quote
Hello!
It's been a few years, but I had a similar problem with a friend's car back then.
I can only say that it was an Audi A4, also with a 1.8 T engine.
I can't remember the exact symptoms anymore; it's been too long, but back then I had to replace the turbo.
The wave, which operates the spark plug valve, was completely dislodged from its housing. Really extreme.
Take a look at this as well.
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 TDI: Intermittent Engine Misfire - Causes & Fixes On-Board Diagnostics (OBD)
No new posts 2.0 TDI CRLB engine occasionally fails to start Diesel Engine Technology
No new posts Engine Control Unit No Power: Intermittent Starts, Heat I... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Sporadically high loading pressure? On-Board Diagnostics (OBD)
