Broken Fuel Line Holder: Causes & Fixes
Post07-07-2015, 18:59    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
Hi.
The part number 3C0130308D (these three metal tubes in front of the valve cover) are attached to the two outer brackets on my intake manifold.
One is broken (or has been broken).
Do they really not come individually?
Google is returning a part number, 036103733D, which is described as a "clip."
Can someone tell me more about it?
Thank you.
Translated on 13-09-2026, 14:58.
Post07-07-2015, 19:29    Subject: Broken Fuel Line Holder: Fix & Replacement Quote
dieselmartin wrote:
DuckDuckGo returns a part number 036103733D, which is supposed to be a "clip".
Thank you.
3C0130308D was discontinued in 2011 and is now 3C0130308E.
Costs €101.40 gross.
The clip seems to be holding the bundle of pipes in place, and it costs 52 cents including tax.
Translated on 13-09-2026, 15:00.
Post07-07-2015, 22:39    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
Thank you.
Can you see if there is one or two?
Because the tube bundle has THREE, two on the outside with threaded flanges, and one on the inside without.
I need the one with the eyelet.
Translated on 13-09-2026, 15:01.
Post07-07-2015, 22:54    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
Three. Only one type is available as a replacement.
I'll just order them. They don't cost much, and nothing else is listed.
Translated on 13-09-2026, 15:02.
Post07-07-2015, 23:07    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
Thank you, Roger.
I'll figure that out eventually.
It's strange that the bracket suddenly broke, the one that's located just behind the timing chain cover icon_evil.gif.
Guess what was replaced just a few kilometers ago.
I just hope that I can get the mesh of clips on and around the new one icon_wink.gif.
Post15-07-2015, 20:00    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
Too bad.
It is not 036103733D.
This is a hose holder attached to the left engine bracket icon_sad.gif.
Then, the bracket that was already glued will now have to be secured with a cable tie (oh, how ugly icon_sad.gif).
 File size:  75.95 KB
 Viewed:  880 times
 File size:  112.72 KB
 Viewed:  723 times
 File size:  122.45 KB
 Viewed:  1814 times
Translated on 13-09-2026, 15:03.
Post15-07-2015, 21:07    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
I just hope I can get the mesh of clips on and around the new one
Tip: If possible, try to slide it sideways.
Translated on 13-09-2026, 15:04.
Post15-07-2015, 21:58    Subject: Broken Fuel Line Holder: Causes & Fixes Quote
dieselschrauber wrote:
I just hope that I can reattach the mesh of clips to and around the new one
Thank you, but that's no longer relevant.
Because I can only get the new bracket for all my pipes, and it costs over 100 EUR, and then it will be attached and ready icon_smile.gif.
So, we're sticking with the cable tie.
The part fits very tightly and it holds very securely... it just looks very unimpressive icon_sad.gif.
Translated on 13-09-2026, 15:05.
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cable Clips for Car Hood/Bonnet Contact Transmission, Chassis, Body & Interior
No new posts Golf IV ESP Adapter: Does AHH fit AFN? Diesel Engine Technology
No new posts SW Halter neu machen oder lassen? Transmission, Chassis, Body & Interior
No new posts Broken 1.9 TDI AFN Camshaft: Causes & Fixes Diesel Engine Technology
